Question about HP PSC 2210 All-In-One InkJet Printer
Won't initialize make clicking sound when turned on. Won't initialize. Keeps clicking.
I cleaned the scanner mirrors/glass/sensor and it solved the problem.
Posted on Aug 12, 2008
    Guru:
  • 1,049 Answers
You've stripped something out, its a mechanical problem. Probably on the bar that drives the print head.
Posted on Aug 05, 2008
Tv screen keeps going off and on how to fix it
Sounds like you have an intermittent power supply issue.
Feb 05, 2016 | Televison & Video
I have a 2004 chevy cavalier and it won't start. Just keeps clicking and won't turn over. I need some help please. Thanks
use test light, connect clip on grnd. , touch tip on the starter wire while turning key , if it lights starter is faulty , no light, solenoid is faulty, if it lights and indicates starter is cause you can try to gently tap starter with plastic handle of screwdriver if tapping gets it moving then brushes in starter are dirty or near worn out hope this helps
Mar 19, 2013 | Cars & Trucks
M 1624 led lights up when turned on but just keeps clicking and won't come on
Sounds like a bad HDD. Remove HDD and test, replace if necessary.
Jan 26, 2013 | Gateway M-1624 Notebook
External hard drive won't boot up.
As virtualhost said, maybe you have not initialize this disk and partition it. Additional to disk mgmt, you could use this software
Sep 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
My galaxy s won't switch on fully
I had a similsr problem but with a different model of phone, had to contact the provider as the phone was stuck on 'continually updating' and when it was like that you could do absolutely nothing with it. Call yoiur provider or drop by a kiosk with a knowledgeable attendent. Good Luck
Jun 06, 2012 | Samsung Galaxy S GTI9000 Smartphone
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Screen says "initializing..." and won't do
turn off then wait 2 min, then turn back on.
Aug 02, 2011 | HP PSC 1610v All-in-One Printer
In Super Mario Bros Nintendo DS The last castle in World 8
Try to move around, if you cannot keep turning the game off.
Nov 24, 2008 | Nintendo New Super Mario Bros. for DS
Battery light keeps coming on and steering wheel noise
Initially, would suspect that the vehicle has a loose belt that is common to the power steering pump and the alternator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 13, 2008 | 2004 Saturn VUE
HP PSC 2210 All-In-One InkJet Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
