My Maytag Centennial will not fill with water on the wash or rinse mode. I can hear it click to tell it to fill but it will not. It does spin. I do have water at the kitchen sink so I know it is not a water problem.
    Sergeant:
  • 170 Answers
Your cold water line to the washer is most likly plugged.shut cold water valve of going to washer remove cold water line from washer clean screen in water inlet valve. the screen is in the valve were the line comes of washer.make sure you put the screen back in as it has to be there. flush out cold water line in bucket before putting it back on washer,, good luck thanks for voting
Posted on Mar 24, 2011
When starting the machine its starts washing without filling
This could be because the water level fill switch assembly is bad and it is telling the washer that it is already full of water.
Nov 27, 2013 | Maytag Centennial MVWC500V Washer
My Maytag Centennial Washer is a top loader. It washes fine, but will not spin out after the rinse cycle.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 21, 2013 | Maytag Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
138 people viewed this question
Top Washing Machines Experts
