Question about Sub-Zero 632 / S
My 632 is flashing EC 40. What is the problem?
  • 28 Answers
EC 40 is excessive freezer run time. Something is causing it to run longer than it should could be a dirty condenser could be a stalled condenser fan motor could be a defrost problem.could be refrigeration related. Call and authorized Subzero services. If someone does not know what the code means they are not authorized.
Posted on Jun 02, 2015
    Scholar:
  • 79 Answers
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Posted on Mar 24, 2011
How do you reset the subzero unit after cleaning coils
Hold the alarm pad for 15 seconds. Then when it comes back call an authorized servicer.
Jul 02, 2014 | Sub-Zero 632 / S
Service flashing and ec
what # follows the ec ?
Apr 06, 2013 | Sub-Zero 632 / S
40 ec fix sub zero
check on top of subzero with it shut off and you will see a fan pulling air through some fins. those need to be clean and free of dirt if not your system will not get cold enough to meet the thermostat requirements. or you could have a bad thermostat.
May 26, 2012 | Sub-Zero 632 / S
My sub zero service light and EC 24 are flashing, fridge is getting warmer...suggestions?
The ec 24 alarm is from a sensor that is located behind the freezer wall and connects to the control board in the ref. When the temp gets to a certain point the sensor will trip giving the alarm. If the temperature in the freezer is gone up but is around the 20 -30 degree F range, I would remove the grate that covers the compressor and check to see if the fan is running and if the coils are dirty. Either one of those can cause temps to go up. If the fan is running and the coils are clean, Call a service company because you possibly have a sealed system issue
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 06, 2012 | Sub-Zero 632 / S
Sub Zero service light flashing
nope. check the code. ec?
Mar 09, 2010 | Sub-Zero 632 / S
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
1,011 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
