Question about Casio GShock Riseman AltiTherm GW92001 Watch
I have an analog atomic watch that will not set. I've tried everything. Thanks for any advice!
4 Suggested Answers
Nobarai
  • 57 Answers
SOURCE: Casio WV58A-9AV Atomic Watch Signal Symbol
When the logo is not shown in the bottom corner, the watch hasn't got a signal yet. put your watch on a window sill, and hold the Forward buton until the watch says GET! Form there, the watch will either display ERROR, if it couldn't find a signal, or will have the latest and most accurate time. The watch is also probably set up for auto detect, which is best. To do auto detect, before going to bed, the watch will try to get a signal from 12 midnight, to 5 in the morning.
Posted on Nov 16, 2008
SOURCE: casio g-shock mtg-900 gets ERR when trying to set atomic time
Did you go to Casio and download the manual? I just did after my battery change and I hoping it updates tonight at 2,3, or 5am with my watch in the window.
Posted on Nov 28, 2008
escapement
  • 2334 Answers
SOURCE: Have new Casio Wave Ceptor
Try this link: world.casio.com/wat/download/en/manual/ - 23k - Cached - Similar pages
Posted on Dec 18, 2008
The invicta 4048 is an atomic watch with 4 buttons only. I need to know how to set this watch. Previous experts have refered me to the standard Invicta instructions PDF. The atomic watch is not covered...
The Invicta Atomic 4048 is "discontinued", and Invicta is not very helpful. They do NOT offer an instruction manual for the 4048, because it's discontinued. You can call Invicta at 800-327-7682 then you have to ask for "Melvin" who only works until 1PM eastern time. OR you can do the following:
Hold down the 8 0'clock button until it flashes, select 12hour or 24hour preference, use the button at 4 o'clock to select your time zone (GMT) The watch should reset itself to your GMT time.
Mar 01, 2011 | Invicta Atomic Collection Autotech Analog...
Tip
Watch glossary: A
ACRYLIC CRYSTAL
The inexpensive plastic crystal. It's not very hard and shallow scratches can be buffed out.
ALARM WATCH
A watch provided with a movement capable of releasing an acoustic sound at the time set. A second crown is dedicated to the winding, setting and release of the striking-work; an additional center hand indicates the time set. The section of the movement dedicated to the alarm device is made up by a series of wheels linked with the barrel, an escapement and a hammer striking a gong or bell. Works much like a normal alarm clock.
AMPLITUDE
Maximum angle by which a balance or pendulum wings from its rest position.
ANALOG or ANALOGUE
A watch displaying time indications by means of hands.
ANALOG QUARTZ
The most commonly-used term in referring to any analog timepiece that operates on a battery or on solar power and is regulated by a quartz crystal
ANNUAL CALENDAR, see calendar, annual
ANTIMAGNETIC
Said of a watch whose movement is not influenced by electromagnetic fields that could cause two or more windings of the balance-spring to stick to each other, consequently accelerating the rate of the watch. This effect is obtained by adopting metal alloys (e.g. Nivarox) resisting magnetization.
ANTIREFLECTION, ANTIREFLECTIVE
Superficial glass treatment assuring the dispersion of reflected light. Better results are obtained if both sides are treated, but in order to avoid scratches on the upper layer, the treatment of the inner surface is preferred.
ARBOR
Bearing element of a gear (s.) or balance, whose ends-called pivots - run in jewel holes or brass bushings.
ATMOSPHERE (ATM)
Unit of pressure used in watch making to indicate water-resistance
ATOMIC TIME STANDARD
Provided by the U.S. National Institute of Standards and Technology, Time and Frequency Division, Boulder, Colorado, atomic time is measured through vibrations of atoms in a metal isotope that resembles mercury. The result is extremely accurate time that can be measured on instruments. Radio waves transmit this exact time throughout North America and some "atomic" watches can receive them and correct to the exact time.
AUTOMATIC
A watch whose mechanical movement is wound automatically. A rotor makes short oscillations due to the movements of the wrist. Through a series of gears, oscillations transmit motion to the barrel, thus winding the mainspring progressively.
AUTOMATIC WINDING
A rotating weight, set into motion by moving the wrist, winds the going barrel via the gear train of a mechanical watch movement. Automatic winding was invented during the pocket watch era in 1770 by Abraham-louis Perrelet, who created a watch with a weight swinging to and fro (when carried in a vest pocket, a pocket watch usually makes vertical movements). The first automatic winding wristwatches, invented by John Harwood in the 1920s, utilized so-called hammer winding, whereby a weight swung in an arc between two banking pins. The breakthrough automatic winding movement via rotor began with the ball bearing Eterna-Matic in the late 1940s, and the workings of such a watch haven't changed fundamentally since. Today we speak of unidirectional winding and bi-directionally winding rotors, depending on the type of gear train used.
AUTOMATON
Figures, placed on the dial or case of watches, provided with parts of the body or other elements moving at the same time as the sonnerie strikes. The moving parts are linked, through an aperture on the dial or caseback, with the sonnerie hammers striking a gong.
on Jan 11, 2010 | Watches
I need a full manual for G-shock Atomic
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Nov 12, 2010 | Casio GShock MTG MultiBand Solar Atomic...
My atomic watch wll not let me to select the proper city code (NYC) or make any other selection to reset the time. It was great for four months after Christmas (a gift) but the battery ran out in April. ...
My best advice to you is to contact Dakota or send to Dakota. It may not be what you want to hear, but its probably going to be your best interest to send back to them so they can properly care for your watch.
http://www.buydakotawatches.com/faq.aspx
Good luck.
Aug 12, 2010 | Dakota Watches
How do I set the digital time on a Casio G-Shock AWG-101
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Mar 15, 2010 | Casio Watches
G-Shock Atomic Solar watch - ERR in atomic time keeping
The watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 13, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
Lost manual to set atomic 4045 watch
Unfortunately no. You will need to try contacting Invicta direct. Sometimes you can go to Invicta retailers and they will have some left over or they will have instructions for similar models.
Mar 26, 2009 | Invicta Atomic Autotech 4051 Watch
Nov 14, 2008 | Casio Atomic Timekeeping WV58A 9AV Watch
Casio g-shock mtg-900 gets ERR when trying to set atomic time
Oct 29, 2008 | Casio Atomic-Solar MTG900 Watch
Casio GShock Riseman AltiTherm GW92001 Watch Logo
105 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
