Question about Dryers
Is there a thermal fuse, my dryer won't run when I press the start, get nothing. Where is it located? This is a Roper elect. dryer
  • 96 Answers
Thermal fuse is lacated behind the rear panel on the duct off the blower about 6 o clock
Posted on Mar 24, 2011
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
My dryer will not turn on, there is current to electric plug.
The thermal fuse is located on the back side of the dryer. If you see lint built up that fuse can be melted. If it is melted then the motor won't run because that fuse is in the same circuit as the door switch. So if the fuse is good look for a bad door switch.
Roper dryer tuneup
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 11, 2011 | Roper REX5635E Dryer
Dryer won't start
This usually caused by a blown thermal fuse on the blower housing located behind the rear access panel. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Unplug the dryer or disconnect power then remove the rear access panel. Locate the thermal fuse then bypass it for troubleshooting purposes.
Bypass the thermal fuse by disconnecting the wires and joining it together. Insulate properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Clean the lint filter and make sure the vent system is not restricted then replace the thermal fuse including the cycling thermostat (thermistor for other models) as a standard operating procedure and preventive measure. The thermal fuse usually cuts out due to a failed cycling thermostat(thermistor for other models).
Jul 19, 2011 | Roper REX3614KW Electric Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Rex4635eq2 electric dryer. all switches and fuses check out. Nothing comes on and the timer doesnt move or make a clicking noise when i push the start button. what do you think? Timer? Gary
You need to check your door switch and thermal fuse. The thermal fuse is located behind the back panel at about 6 oclock. If the thermal fuse is bad, you need to make sure the vent is clean.
Mar 26, 2011 | Roper REX4634KQ Electric Dryer
Will not heat
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Aug 03, 2009 | Roper Dryers
Dryer won't start
IT SOUNDS TO ME AS IF YOU HAVE A BAD DOOR SWITCH. YOU CAN TRY JUMPING THE SWITCH OUT TEMPORARILY JUST TO SEE IF THE UNIT RUNS.
Mar 07, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer will not start it is electric
The thermal fuse is probably open again, This condition is caused by restricted air flow out the vent system. Replace thermal fuse again and clean the vent hose and vent hood outside
Jan 05, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not start but timer works, although it tics in the OFF position
Hi thanks for the question. On that dryer In the back you will find a thermal fuse located on the air duct. A small plastic piece with 2 blue wires to It . Replace the thermal fuse
Dec 16, 2008 | Roper REX3614KW Electric Dryer
Roper dryer
ROPER DRYERS ARE MADE BY WHIRLPOOL. ON ALL CURRENT DRYERS, THERE IS A THERMAL FUSE THAT WILL
DISABLE A DRYER IF AN OVERHEATING PROBLEM OCCURS. THE THERMAL FUSE IS GENERALLY A SMALL WHITE ITEM FOUND IN THE REAR OF THE MACHINE, DOWN
ON THE EXHAUST DUCT BEHIND THE BACK PANEL. THERE ARE TWO WIRES ATTACHED TO IT. IF YOU DON'T HAVE A METER TO CHECK IT, FIND SOMETHING THAT IS INSULATED
ELECTRICALLY TO SHORT THE TWO WIRES TOGETHER.
IF THE THERMAL FUSE IS BAD, THE DRYER WILL RUN WITH THE TWO WIRES SHORTED TOGETHER. REPLACE THE THERMAL FUSE. ALSO, CHECK TO MAKE SURE THAT THE DOOR SWITCH LEVER ISN'T BROKEN OFF. IT IS LOCATED IN THE UPPER RIGHT CORNER OF THE OPENING OF THE DRYER WHEN YOU OPEN THE DOOR. THE DOOR SHOULD
PUSH IT BACKWARDS WHEN YOU CLOSE THE DOOR.
TRY PUSHING IT WITH YOUR FINGER. YOU SHOULD HEAR IT CLICK. IF NOT, REPLACE THE DOOR SWITCH.
EITHER PART SHOULDN'T COST MORE THAN 30 DOLLARS.
Mar 31, 2008 | Roper RGX4634KQ Gas Dryer
Open Questions:
Dryers Logo
Top Dryers Experts
