Question about Sony PSPgo White Console
There seems to be no power. is this common and how can i fix it?
  • 64 Answers
Check the battery.. if you turn on your sony PSPgo.. some problem of that device is flex cable or ribbon..
Posted on Mar 24, 2011
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
Very pronounced mid-rangy hum immediately after power-up with nothing connected to it. None of the controls (vol/tone) seem to affect it. Is this a common problem with an easy fix?
Probably bad Capacitors in you Power supply or Amp board.
Open up, check for popped or bulged caps.
If not, take it to a shop.
Careful, it might get worse...
Peace-
Jan 09, 2016 | Mackie Thump 15 TH-15A Powered Speaker
Kenmore 4027
Will not power on at all. This seems to be a very common problem so if you have fixed this without paying a tech I love to know.
Feb 24, 2014 | Kenmore 40272 3.5 cu. ft. Front Load...
My samsung LNT4061FX/XAA is flashing/blinking
There seems to be a common issue on several Samsung's where picture flickers/blinks. I first started seeing it a few months ago here and in the shop where I work.
Samsung is in some cases repairing it for free--seems the problem is on the power board (scene changes) can trigger it.
Solution in most cases is to REMOVE a jumper plug/or wire on the power board. A design flaw of some kind not anticipated by them.
A call to Samsung will resolve this either by them fixing for free or confirming this is the case---seen about 8 sets here where it did fix the set.
May 30, 2012 | Televison & Video
My dash radio and power window and door lock lights go off when daytime running lights switch to night lights
This seems to be a common problem with the Impalas. Most find that replacing the headlamp switch fixes the problem. It seems the dimmer inside the switch tends to fail causing the dropout when in night lights mode.
Dec 14, 2011 | 2002 Chevrolet Impala
Common Polaroid TV Problem-no picture but sound works
Failed capacitors are common problem in LCD TV's and Monitors. Each power supply uses different caps size and value. You should inspect the power supply module first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 25, 2010 | Polaroid 4241-TLXB 42 in. LCD Television
Dell W4201C half black screen
It should be easy enough for a Novice to fix.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 03, 2009 | Dell W4201C 42 in. Plasma HDTV
Plugged in not charging
Is the laptop still under warranty, if so get it repaired under warranty. If you try and fix it yourself you most likely would void your warranty. Power problem are quite common with laptops especially with the power socket on the laptop and the power plug which plugs into the power socket. These problems can be fixed, but I suggest you try to get yours fixed under warranty.
Jun 14, 2009 | Gateway Computers & Internet
Monitor will not power up
This sounds like the common STR type regulator IC problem that goes bad with most of these samsung monitors. Not a hard thing to fix,but withg the hi voltage and the safty issues involved, It would be best to have a pro fix this for you. Good Luck
Jun 14, 2006 | Samsung 997DF 19" CRT Monitor
Sony PSPgo  White Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
