Ms Mason,
With Windows 7 there comes an improved Compatibility feature which allows you to run programs apparently not functional in Windows 7. In order to do this, please install the program as usual, making sure to tell the installation program to install a desktop icon. When it is finished, right click on the icon and select properties. The next window has a tab called compatibility. Click this tab and select Run program in... and select Windows Vista or Windows XP SP3 (either should work). I would also set it to run as administrator. See graphic below.
If the program wont install at all, than explore the CD and do the same process with the "setup.exe" program on the CD.
Good Luck,
NOLA Tech
