Question about HP Officejet 5610 All-In-One InkJet Printer
The scanner dont work in my HP officejet 5610 all in one
When I press the button SCAN I have a message "without opption of scan."
And in My computer I tray to open the "officejet 5600 series" "image scanner" and I have a message "the scanning software could not be found or your scanner is not connected".
what should I do?
  • 5 more comments
  • Anonymous Nov 03, 2008
    My all in one is asking me to look at my manual when I press scan.
  • Anonymous Dec 18, 2008
    When
    When I press the Scan button on the 5610 All-In-One I get computer not connected message. I can print from the computer and when I press the Copy button it does copy from the scanner bed.
  • Anonymous Mar 18, 2009
    I HAVE THE SAME PROBLEM MY PRINTER IS WORKING BUT THE SCANNER IS NOT WORKING
  • Anonymous Mar 22, 2009
    when i want to scan it says no scan option set
  • Anonymous Apr 16, 2009
    it says i cant scan cause i have no connection
  • hamza_malik1 May 14, 2009
    when i open scanner answer coming scanner is not installed or not connacted
    Problem Solver:
  • 4 Answers
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ... HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
Posted on Aug 05, 2008
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
27
Posted on Apr 05, 2009
It worked. thanx
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Scanner computer cant comunicate
What do you want Darrell?
Code reader or Professional scan tool?
I think your going to need a shop to work on it
Without wiring diagrams your done
You have to chase every wire from the under dash
connect to their ends, until you fix the issue & can
connect to the Bus & Data stream,we can't help with that
Jul 17, 2014 | Office Equipment & Supplies
Canon pixma mx 922 will not scan
This happen due to poor version of drivers.Make sure that you install latest drivers. If you don't have then download it from PIXMA MX922 Canon Software Driver
For more help or guidance check Canon MX922 Manual English
Jul 28, 2013 | Office Equipment & Supplies
Samsung SCX-3201G printer driver free download
Samsung SCX-3201G printer driver no download plzzzzz help me
Jun 21, 2012 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
3,797 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
