Question about Refrigerators
Why won't my inside lights come on in my True GDM-72
  • 1 more comment
  • Marvin
    Marvin Mar 24, 2011
    What is a True GDM-72???????????
  • jwoodk10 Mar 24, 2011
    True Manufacturing Company Model GDM-72 store refrigerator
    I tried the switch at the top & bulbs are good. The lights still won't come on
  • 1,262 Answers
Usually controlled by a switch located either in the door hinge or at the top of the door. Be sure the bulbs are good and of the correct voltage.
Start there and let me know if I can be of further help.
Posted on Mar 24, 2011
  • Dennis Boxerman Mar 24, 2011
    the next most logical step is to check to see if you are receiving the proper voltage to the socket that the bulbs are screwed in to if they are incandesant type bulbs.. If your unit is equiped with flouresant bulbs, then look for ballast and possibly transformer and starter issues. don't check socket for voltage on flouresant, could get shocked. There are a variety of configurations out there. Let me know more info if this does not get you there.
Why gdm 72f cap tubes
That freezer is meant to have a stable load an example is storage. A supermarket application would require a tx valve.
Apr 28, 2014 | True 72 cu. ft. / 2039 liter Commercial...
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Where are the Freon nodules for a True GDM-72 cooler?
SEALED SYSTEM REPLACING COMPRESSOR ON COMMERCIAL FREEZER
Aug 08, 2013 | True 72 cu. ft. / 2039 liter Commercial...
True 3 door refrigerator model#GDM-72 door does not self close
hi, I lost a part of the true cooler model gdm-72 door part that let the door side itself to close
Nov 01, 2012 | True Refrigerators
Do I have to use a TRUE thermostat on my T-72?
The True thermostat sits on the evaporator in a piece of tube attached to the coil. If it won't switch off at your required temp even at position 1 you can use an air temperature type thermostat in it's place. It will sit in the same place but the sensing end will coil up behind the fan. Get a bar fridge thermostat and it'll adjust to your needs.
May 18, 2012 | True GDM-72 Refrigerator
True gdm 72 goes below 20 degrees
Usually a blocked condenser fooling the thermostat into running overtime. Possibly thermostat fault but less likely
Apr 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Water dripping from inside top to bottom of cooler what is causing this and how can i fix it?
Coolers like yours create a lot of condensate. Every time the door is opened warm moist air enters and changes back to a liquid state on the evaporator coils behind the fan and area you see moisture dripping down from top and back wall should be going down a drain pipe to the bottom of cooler and into a pan where a fan blows warm air over the condensate/water returning it back into the store or business that the cooler is located. Looking inside there shoud be a tray or pan that is at the base of the evaporator. True uses different parts but you need to see why the water is leaking from. If cracked tray or line blockage causing overflow into the cooler. Click Here=> Leaking Refrigerators and then again here=> Leaking Refrigerators! This will help you get a better idea of what I am talking about, if helpful please rate. True MFG. does not share their information to me. I would need to be their registered customer to get answers. Click Here=> E-mail True Technicians I also think if you have questions for them they ask for your model number as a reference. They Will answer you just need that number along with GDM-72-RC I will be here if you have questions, Thank You, Sea Breeze
Oct 13, 2011 | True GDM-72-RC Refrigerator
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Where do i find the starters for the florescent lights on a true gdm-72
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Nov 12, 2009 | True GDM-72 Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
