SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
SOURCE: my keurig coffee maker turns its self off, even
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine. 2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle. 3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal. 4. Reassemble KCup cradle and reinsert it back into coffee maker. 5. Power on machine. 6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
