Question about Maytag MMV4205 Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came back. The next day I tried to melt some cheese on top of some food and put it in the microwave. The loud noise was there and it didn't cook anything. After 2 minutes, the food was not even warm and you could smell like a burning rubber smell from the microwave.
    President:
  • 670 Answers
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Posted on Mar 24, 2011
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
A failed magnetron does not make noise unless it is internally shorted. I have repaired thousands of ovens, and have never encountered this. A shorted stack rectifier (diode), or a transformer with shorted turns, or a defective (leaky or shorted) capacitor will cause the oven to be noisy, and not heat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on Mar 19, 2016
1. Microwave noise 2. keyboard and beeping
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded.
Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
Mar 14, 2016 | In Microwave Ovens
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Coleman EB15A - Buzzing noise from transformer area, no heat or fan
    see this causes and proceed. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 18, 2012 | Microwave Ovens
    GE Microwave (JVM1860CD001) control board buzzes.
    see this causes and fix it. God bless you
    Oct 10, 2012 | GE Microwave Ovens
    My microwave makes a loud humming noise when it is turned on.
    May as well use the microwave as is until it terminates naturally. All microwave ovens buzz, that nothing unusual, but although you can replace a Magnetron, the cost is unusually high. By the time you take the oven down, open the case and fuss around, perhaps not making things any better; the fact is; a new replacement with a warranty is just over $100. Why bother?
    Feb 04, 2018 | Microwave Ovens
    I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
    Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
    May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
    Turntable does not turn and fan won't exhaust
    The second problem is probably defective door switches, or it may be a problem with the control panel, which we repair nationwide for only $32.50. On my Web site, I have info on safety, disassembly, and diagnosing and replacing door switches: http://tinyurl.com/yzjozk Running it empty has damaged the magnetron. It will work for a while, but it will eventually have to be replaced. A good parts source is here: http://tinyurl.com/gv383
    Jan 05, 2007 | GE XL1800 1100 Watts Microwave Oven
    Maytag MMV4205  Microwave Oven Logo
    1,348 people viewed this question
    Top Maytag Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
