Question about Vacuums
Edmark steam brush
How to put water in an edmark steam brush
Hi
press small release button on steam supply cotroller lever and pull the lower portion towards you
. now inyour righthand is your water filling tank . open the cap 7fill baout 100ml of water & close the cap put this back to the main unit just by gently pressing towards to the unit
It is done nolw wait for 30 sceconds & start using
Thanks
Posted on Apr 21, 2009
No steam or water even coming out, its just quiet except brushes moving
David, the brushes on the motor may be burned out and the conduction process has been compromised. In short the motor is bound up and won't turn. This can happen if surface debris collect on parts of the motor. Do not turn it on for long and let the unit get warm as it will eventually break down permanently.
If you need a manual, go the company web site and seek that from customer services.
Mar 10, 2014 | Bissell 46B4 Stick Steam Cleaner
Steam Vac Ultra five rotating brushes won't ****
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN.
Dec 18, 2012 | Vacuums
I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
see the causes and fix it. God bless you
stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    Eco steam mop no steam
    see this causes and use the common sense. God bless you
    nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
    Sep 19, 2012 | Vacuums
    I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
    You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
    Thanks for asking.
    Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Is there any reason the water won't come out?
    You need to replace the pump belt, that is why the water is not dispensing and you need to replace the brush belt, that is why the brush isn't spinning. Here are the belts you need.
    Bissell Powersteamer Belts
    Feb 04, 2010 | Bissell Powersteamer 1694 Upright Vacuum
    Help for free???? my spin brushes won't spin
    I have the 7443-940, and on this one, the brushes are powered by the water coming from the water pump. If there is no water in the unit, they will not spin. I do NOT know if yours is the same way, but it's worth trying it out.
    Oct 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
    I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
    the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
    Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Bissell carpet shampooer wont dispense water
    Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
    Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Vacuums Logo
    1,027 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
