Question about Whirlpool WFW9200S Front Load Washer
What does the code F35 mean when i start my machine it will start and turn for a few seconds and then it stops the code F35 comes on and the machine wont do nothing it still show all the light on but it wont turn.
  • 5,081 Answers
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
Posted on Mar 24, 2011
  • INDIRA KUMAR
    INDIRA KUMAR Mar 24, 2011
    The following link explains the error in more detail and how to correct:
    http://www.fixya.com/support/r3608687-su...
    NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
    COURTESY:jsrock - A senior expert of fixya...
Code Lo
Betcha there is a small battery inside that helps maintain the computer's ROM. Since this is a sears machine call Sears/Kenmore parts and see what they can offer you in the way of help.
Oct 02, 2012 | Kenmore 19110 Computerized Sewing Machine
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
What is error code f35
Error Code F35 = Analog Pressure Sensor Failure
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
Possible Causes / Procedure:
* Check if pressure hose is fixed correctly.
* Check if the airtrap is not blocked.
* Check if the hose is not blocked.
* Unplug or turn the circuit breaker off for 30 seconds.
* Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
* Press the Pause / Cancel / Stop button twice to clear the display.
* Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note:
Hope this helps (remember to rate this answer).
Apr 01, 2011 | Maytag EPIC MFW9700S Front Load Washer
What does code f35 mean on my maytag 5000 series washing machine?
I found this for you:
"F35" Analog Pressure Sensor Failure
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Mar 07, 2011 | Maytag MAH8700A Front Load Washer
Once you start aload in few minutes SUD sign comes on after few minutes F35 code comes on. We try to clean the washer also,even after that same code is coming on .
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Feb 19, 2011 | Kenmore HE3T Washer
Machine stopped with code of F35
F34, F35 and F36 are fusing errors.
To unlock:
- Turn off machine
- Turn it on while pressing keys 2 and 5 simultaneously
- On the menu that shows up, press 1st option "Software SW"
- Using the up and down keys, navigate to switch 3-1
- Press OFF
- Cycle machine power
Don't mess with anything else or you'll risk more trouble than you're having right now.
If the error comes up again, you have something wrong with your fusing unit. Check it.
Mar 06, 2010 | Washing Machines
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Whirlpool WFW9200S Front Load Washer Logo
230 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
