Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
I have a KitchenAid KUD1021RWHO dishwasher that will not turn on when I hit the start button. The LED lights work when I press cycle selection ie. "normal" but when I press the start button nothing happens. I have waited for a couple of hours and then it will start. However during the last week it has happened more frequently and now it has not worked for the last (2) days. Any ideas as to what the problem may be? Thank you for your help!!!
  • 55 Answers
This is a very common issue on these units. The touch pad has failed. You can try to flip the breaker off for several minutes and see if that clears the code. More than likely the touch pad will need to be replaced.
You can purchase the part from the link below.
Appliance & Refrigeration Repair
Posted on Mar 24, 2011
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
KitchenAid KUDI10FL dishwasher- The door spring system broke and I repaired it, but now all of the sudden the dishwasher will not start. The door may have been dropped a couple of time before the spring...
Hi- It is possible that the door latch is not completely engaging. If the door dropped the hinges may have bent a little thus preventing a good contact with door switch. Try pressing and holding the door shut, hard, and pressing start. If that works then replace the latch assembly. It is also possible the membrane switch got rattled with the door falling, or a wire is grounding out somewhere. Hopefully it is just the latch. Hope this helps, good luck.
Sep 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The CLEAN light is flashing and preventing the dishwasher to start.
try this buttons for a reset Hi Temp, Air Dry, Hi Temp, Air Dry. Then Cancel.and see if All lights went on, hit cancel, select cycle, start and see if it works .if not then It's certain that the heater is at fault. Disconnect power and check the heater leads (underneath at the rear of the unit)
Aug 30, 2009 | KitchenAid Dishwashers
Clean light flashes cant get to start a wash cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It's not as common but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Mar 07, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
We have a kitchenaid dishwasher model#kud102irbl serial#FU1705420 Clean light keeps flashing on 7 times, waits a few seconds and flashes 7 times again. How can we repair this?? Dishwasher will not leave...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 26, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Clean light will not go out
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
858 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
