Question about HP Office Equipment & Supplies
HP Officejet 4500 three in one has error 346 and cant fax out. It dials the number correctly but as the fax begins to connect, the number changes to a plus sigh in front of it and puts a dot in between numbers looking just like this. +X.XXX.XXX.XXXX This then cancels the fax connection. can you explain this ?
    Problem Solver:
  • 12 Answers
Error 346 means the connection was interrupted. Try a different phone cord or jack. If you have a voicemail service that 'pulses' the dial tone when you pick up (to let you know you have messages), it can cause that error too; try clearing the messages.
Adding the +1 is normal when dialing with the area code (using a 10-digit number). If you weren't using the area code, try it.
Otherwise, as a last resort, you can try resetting the fax back to factory default:
-turn off and unplug.
-Hold the # and 3 keys down while plugging in the power cord. If that doesn't work, try # and 4.
Posted on Mar 24, 2011
How can i Troubleshooting Fax Issues on my hp officejet 4650?
If you get issues like Faxes can be sent but not received, Faxes can be received but not sent error on your Printer then follow the given troubleshooting steps.
Solution to Faxes can be sent but not received
    ·Initially, you have to check any of the telephone line services are enabled. There are,
    1.Voice Mail
    2.Call Waiting
    3.Billing Tone
    4.Privacy Block
    5.Security Screen
    6.Anonymous Call Rejection
    7.Privacy Manager
    ·These may block your incoming faxes. So disable the above features.
    ·If you are using Automatic fax reception option on your fax recipient, then check whether the Automatic Answering feature is enabled or not, if it enables means Auto Answer green LED should be on.
    ·Check the Ring to Answer value.
    ·If the value set as answering machine that causes the issue on fax reception. Then change the value to Fax or FaxTel
    ·Now, you can receive the incoming faxes.
    Solution to Faxes can be received but not sent
      ·Check whether the dialed number is correct or not. Every one of the digits required to make a telephone call from a similar line must be dialed.
      ·On the off chance that the Speed Dial has been used for dialing or the fax has been sent from your PC, print the page to be faxed and dial the number physically on the HP Fax front board.
      ·Check whether the Tone Dialing is set on you HP Fax product.
      ·In the event that faxes are sent effectively from the HP Fax front board, but, it's fail when sent from the PC, test the communication between the HP Officejet 4650 printer and your PC by tapping the Status button in the HP Director application, or attempting to print some record.
      ·If the printing fails to send the fax, then check whether all cables (from system to HP Officejet 4650 Printer) are connected properly, if it's not then connect it properly.
      ·Now restart it. On the off chance that communication still can't be set up, Call Printer customer service team via Toll-Free: +1-800-836-3987 to resolve your HP Officejet 4650 fax issues.
Jun 27, 2017 | HP Office Equipment & Supplies
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My HP officejet 4500 wireless will send faxes but will not receive faxes...why?
There could be a couple of reasons,
1. incorrect phone number
a. Unplug the fax line from the wall jack and plug in a regular telephone.
b. From another phone call the phone that you just installed.
c. If it rings, the number is correct.
2. Could be bad phone wire from wall to fax
3. Could be bad fax card in printer.
4. Did it ever work?
Mar 30, 2011 | HP LaserJet 4500 Printer
My fax machine will not send. When I dial the number it does nothing. This just happened and I have faxed on it before.
No polling capability at remote side.If th number you dial is a Personal Web Server it only supports 10 concurrent connections. HP Toptools usually uses 3 connections for each user, so after three users invoke Toptools, PWS starts to slow down. Rapidly changing tabs can result in too many connections temporarily.
Dec 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
When faxing error code 346 to one number so far what is error code 346
Here is the link to the solution to the error code as posted on the HP Solutions Web site:
<http://tinyurl.com/lu699e>
Jul 07, 2009 | HP OfficeJet 4315V All-in-One Printer
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Fax Error Codes
ERROR 346 The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
Sep 11, 2007 | HP Officejet 7210 All-In-One InkJet...
990 people viewed this question
Seeker5211
Seeker5211
