Question about Microwave Ovens
My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can you point me to items to check? I am comfortble with replacing a motor or sensor if we can narrow down the problem. Thanks.
  • 9 more comments
  • jstreinz Mar 24, 2011
    Thanks. I am familiar with the sensor and it is in the correct position and it is plugged in. Anything I can do to by pass it?
    I am still not sure how to tell what the problem is so I can repair the machine, can you help me?
    Still in need of direction, please.
  • jstreinz Mar 25, 2011
    Hey Mobilan, I soaked the pump over night and then ran the clean cycle as you suggested but still no water being pumped over the plate. I took the pump out and removed the cover and the shaft turns very easily. I am not very electrically enhanced nor do I have equipment but is there a way for me to test the pump? I guess I want to make sure the problem isn't with another component like the ice level sensor. Your thoughts?
  • jstreinz Mar 26, 2011
    Did you get my last reply asking for additional assistance?
  • jstreinz Mar 27, 2011
    I have been waiting since Friday for a reply to a question, can someone else help me? Can you see all of my messages?
    Thanks.
  • jstreinz Mar 28, 2011
    Hi Kelly, thanks for getting back with me. The resvr fills with water as it should and immediately when turning on. From there it does not pump water over the plate. The sensor is plugged in and I removed and replaced it. Is there a way for a non-tech to test it or by-pass it for a test?
    Joel
    Hey Kelly, thanks for your reply. I will take a look at this when I get home from work. FYI, it appears that the plate is getting cold as you can see a light frost that forms on the plate but no water runs over it.
    Thanks Kelly, so what are your thoughts on what I should be looking at? I have the plate pumping pump out, is there an easy way to test it?
  • jstreinz Mar 29, 2011
    Hi Kelly, I am a bit confused as what to check on or how to determine what my problem is. I do have the pump that puts water on the plate out of the unit and I am wondering if there is a way for a lay person to test it. Can you help me in getting this project wrapped up? Thanks.
    Joel
    I keep getting this same message, have you been getting my reply questions?
  • Microwave Ovens Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
The use and care manual is here:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
Here as a note from the manual:
IMPORTANT: Every time the icemaker is
turned off, you MUST clean the icemaker
system with the Nickel Safe Ice Machine
Cleaner. See Care and Cleaning-Icemaker
system
section for instructions
Knowing the unit was off for 2 weeks and then the problem started there may be something stuck in the inlet water valve. Remove power, TURN OFF THE WATER SUPPLY, follow the water supply line to the inlet water valve and remove the solenoid and then the armature cylinder on the top of the inlet water valve. There will be a needle, and spring inside so be careful NOT to lose them. Remove any debris from this area and carefeull remove / lift out the diaphragm. Wash the diaphragm / seals under slow running water by just rubbing your fingers over it. Depending upon the type valve you have there can be as many as 3 holes in the diaphragm. Center and 2 pin holes within 1/8" of the outer circumference. Make sure the pin holes (if any) are free of obstructions. Usually if the pin holes are a problem the water will not shut off. Before reassembling the valve briefly have someone turn on the water supply by doing 1 Instant ON / Off cycle to flush out the valve. 1 or 2 seconds tops. If you don't have water.... at this point the inlet water filter is clogged or the main water supply valve (utility connection shut off valve) has failed.
Test the resistance of the inlet water valve solenoid. Is should be somewhere between 180 and 480 ohms. Any where in that range should be ok.
If cleaning the inlet water valve & solenoid conponents do not resolve the issue you need to start looking at the sensor probe positon near the ice tray to see that it is in place and was not bumped durong a cleaning process.
This should get you going again. If not respond here with a progress update and we will go from there.
Thanks for choosing FixYa,
Kelly
Posted on Mar 28, 2011
  • 6 more comments
  • Kelly
    Kelly Mar 28, 2011
    Hi Joel, My apology for not getting back to you sooner but was not even at home. You stated that it fill with water... BUT it does not pump water over the tray after filling at all. I not Mobillian had told you to soak the pump overnight (good advice) and you said it turned freely.
    The sensor (thermistor) is what passes the signal to turn on the pump. Knowing you already replaced the sensor (and we can not bypass it without some expensive variable resistor circuits / equipment) Lets just assume the problem is NOT the sensor / themistor. However.... follow the sensor harness back to the control board and make sure that the sensor wiring is properly connected to the control board.
    After that start looking at the control board for any signs of corrosion on the electrical runs within / on the board. If you note corrosion use a DRY "Q-Tip" or very carefully use a pencil eraser lightly over the corroded areas. It just seems to me at this point that the sensor signal is not getting to the main board or the main board itself has a problem. I find it hard to grasp that you just turned it off for 2 weeks and all of the sudden it is not working correctly.
    The one scenario that comes to mind is.... that maybe the bypass vavle is stuck open and the ice tray is not freezing so the sensor is telling the main board "hey it is not cold enough yet!" The bypass valve is part of the coolant system plumbing and is physically soldered onto the copper tubing. Just for grins.... use 2 pieces of wood (hammer HANDLES work great) and place one against the valve and then give it a few healthy TAPS to see if it will un-stick Don't hit it too hard... just enough to wake it up. :) Just try not to DENT it.
    You should be able to tell if the ice tray is getting cold or not. If it is NOT getting cold you may never have the pump run at all. (my suspicions at the moment assuming the compresor is running)
    Kelly
  • Kelly
    Kelly Mar 28, 2011
    Disregard.... after re-reading that information I just passed you they were talking about the drain pump!
    Kelly
  • Kelly
    Kelly Mar 28, 2011
    Use this page as a reference to where you have discovered anything:
    http://www.repairclinic.com/Ice-Maker-Fr...
    Note top middle and bottom.
    Kelly
  • Kelly
    Kelly Mar 28, 2011
    I note you stated that you saw frost on the ice plate. (tells me the compressor is running) I am still thinking the main board is not getting the sensor signal for some reason to turn on the pump. Do you know if the pump is even trying to run at all? Does it warm up to the touch at all? This still has me scratching my head but at the moment I am convincing myself it is related to the sensor signal or corrosion on the main board. If you have an ohm meter once the plate is cold kill power to the ice maker and measure the resistance of the sensor at the main board.
    You had asked if there was a way to bypass the sensor... the answer is you jumper in a 60K ohm resistor (<- radio shack) across the sensor terminals.
    I found this out reading a service bulletin.
    http://www.geservicesupport.com/ccweb/Mo... Just take a look at the first 2 pages. The last 2 pages are how to install a drain pump.
    This statement caught my attention:
    The pump senses the water level in the tank with an electronic
    sensor. If the customer turns the unit off and allows the ice to
    melt, the water flowing into the pump may be too pure for the
    sensor to detect. Therefore, water will back up into the bin.
    A 60 Kohm resistor is jumpered across the sensor to prevent
    water backup. If the pump does not have this resistor or if it is
    defective, it will not sense the water level and turn on the pump.
    Each time the pump is turned on it will run for 15 seconds. This
    could be used as a way to drain the bin by manually turning the
    pump on and off every 15 seconds until the bin is empty.
    Somehow I missed sending this post.... and told you to disregard the post before you even got it. Here it is...
    Kelly.
    Kelly.
  • Kelly
    Kelly Mar 29, 2011
    There is a way to test it... but I would seriously have to see it to make the connections. There should be a maximum of 3 wires on the pump. Find the 2 that have resistance on them NOT zero ohms... but something above 480 Ohms and connect a test cord to those terminals to run the pump from an outlet. Just make sure the motor is AC before you make a test cord and plug it in. If it is DC you will have to use a battery and wires from + to - Whatever you do... DO NOT leave the wires from the control board connected when you test the pump. An old household extension wire with the female end cut off works good for fabricating a test cord. I am pretty sure your pump is good.. I am certain that for some reason the main board is not getting the sensor input to the board. Follow the wires from the sensor to the board and then unplug the 2 sensor wires and check for resistance under 70 K ohms across those 2 wires. If you get a resistance reading then the sensor and wires are good. If you don't get a reading... at all find out if the problem is the new sensor or the wiring. I unplug the sensor and jumper the 2 wires going to the control board and read for ZERO resistance / continuity. If that reads good I check the thermistor / sensor for 60 K ohms or less. It can read as low as 1039 Ohms depending on the temp of the sensor. Anything between 1039 ohms and 60 K ohms should be good when reading the thermistor(s).
    Kelly
  • Kelly
    Kelly Mar 29, 2011
    I have a request. Some where inside your ice making machine there is a 4 x 6 envelope taped to the side of the chassis. The envelope should be labeled "Technical Data" or some thing similar. Pull out the sheets from the envelope and see if there is a tech sheet that tells you how to do a self diagnostic. (usually there is one) If you find it follow the steps and perform the diagnostics test. Let me know what the error was as a result of the diagnosis. The envelope will most likely be above the ice bin but that is not 100% sure. Just look for it on all inside panels of the chassis. If your the original owner it should still be inside.
    Kelly
  • Kelly
    Kelly Mar 29, 2011
    This was my answer to your ca a lay person test the pump question:
    Kelly
    Having said the above.... Look on the pump and see what the power requirements are. I am not 100% sure it is 120 VAC or 24 V DC or something else without your schematic that should be in the tech data sheet envelope I mentioned in my last post. If the power requirement is 120 VAC use an ohm meter and find the 2 terminals on the pump that read resistance some what above ZERO. One of the wires is probably a ground but the other 2 wires will be line (neutral) and load power (L1). If you read resistance above 180 ohms across 2 terminals those are the power terminals. The resistance alone should tell you that the moter is most likely good. That is where you make a test cord from an old household extension wire and power it up from an outlet. I really believe that your not getting power to the pump because the main board is not getting the thermistor resistance from the new thermistor your installed.
    Kelly
  • Rwright224 Feb 17, 2014
    thanks for that information,it helped me solve the problem.
  • 8,220 Answers
The pump probably has some calcium/lime buildup on the shaft and is seized up. You need to free it up and then add in some ice machine cleaner and go by package directions. I would use Nickel-guard.
This machine has a water valve as you now that fills the reservoir with water. The pump continually pours the water over the evaporation plate and a slab of ice forms. When the thickness is right the gas is redirected using a hot gas solenoid to toss hot condenser gas briefly through the evaporation plate and loosen the slab. The slab slides down onto a wire grid and gets cut into cubes. While you are at it give the condenser coils a good vacuuming. A new pump is $200 bucks. Let the ice machine cleaner soak the impeller overnight. Might be enough to get her up and running again.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 24, 2011
  • 43,501 Answers
I would check the ice level sensor... it is shown on page 9 of this manual...
If the sensor thinks that the bin is full it will not do anything...
That is why that would be my first area of interest..
heatman101
  • 1 more comment
  • D. Floyd Kolb
    D. Floyd Kolb Mar 24, 2011
    The bin sensor seems to be a thermistor or temperature sensor that cuts the machine off when it gets cold...therefore there would be no way to jumper it out....
    however if the sensor goes to an open postion the board will read it as too cold and it will not let the machine run...
    You could try to jumper the wires... it may read as hot then but it may also sense the complete short and also keep it from running... depends on how the board is programmed...it will not hurt anything to jumper them...
    Other then that there also is a thermostat and a transformer that would be a common part that will fail...
    here is a similar machine to yours and a parts breakdown for it...
    http://www.appliancepartspros.com/partse...
    heatman101
  • D. Floyd Kolb
    I could have given you a line of BS and told you that this or that for sure is your problem...I did not.. I was honest with you in that unless you have a technician actually check the machine and see what the problem is, there is no way to tell from here what exactly your problem is...there are at least three different things that will make your machine do what it is doing...
  • D. Floyd Kolb
    D. Floyd Kolb Mar 28, 2011
    Joel,
    I have been watching everything...bottom line is that if the compressor AND the pump are not turning on then either the bin sensor is bad or the board is bad...
    If the compressor is running but not the pump then the board is bad...
    There are not that many things that can go wrong with the system...
    The sensor can be tested, but you need to know some very technical things that will be hard to find out other then calling the tech support people...
    There is only so much that can be done in a forum like this...unfortunate I agree... but reality...
Have Kenmore sid-by-side refrigerator: 7909621940B - Just changed water filter. Now, no water or ice dispenses. Ice maker is making ice - filled the bin over a few days. But, when I push to dispense...
We also have a kenmore side by side refrig and had the same problem,,,
FIRST, CHECK THE CONNECTION BETWEEN NEW FILTER AND ATTACHMENT POINT,,
IF THE RUBBER GASKET CAME LOSE DURING THE CHANGE, IT MAY BLOCK THE PATHWAY FOR WATER TO FLOW
NEXT, CHECK THE WATER/ICECUBES/CRUSH LEVER SWITCH TO MAKE SURE IT IS NOT PART WAY BETWEEN ONE OF THE SETTINGS,
NEXT,CHECK TO SEE IF YOUR UNIT HAS A RESET BUTTON,
THE RESET BUTTON IS USUALLY IMMEDIATELY INSIDE THE OPENING WHERE THE WATER/ICE DISPENSES AND UP, YOU WOULD NEED TO PLACE YOUR FINGER RIGHT DIRECTLY UP BEHIND THE FRONT PLASTIC COVER, AND IT'S GOING TO BE A VERY SMALL BUTTON, I AM NOT SURE WHICH SIDE ON YOUR UNIT R OR L, BUT DIRECTLY UP IN THE CORNER,,
I HOPE ONE OF THESE HELPS !! angi
Feb 05, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Kelly
Oct 26, 2010 | Microwave Ovens
Its brand new so i'm not sure how it should run. here are my questions and observations. 1. it hasn't stopped running for two days and its the loudest appliance in the kitchen. why? 2. the overflow...
Howdy. I'm guessing you have a new refridgerator with a built in ice maker. although I don't know what the overflow pump might be, the running water sound is likely the ice tray filling.
If the running water sound is continuous, then there is a problem and the water valve that supplies the fridge should be shut off. By now you have likely turned down the temp in the freezer section a little, so I will move on to tell you that the new fridges are mostly ridiculously loud and make as many as 30 different, unsettling noises. Many will even be so bold as to mention this in the user's guide. Ideally, once it has settled in, made its bucket full of ice and come down to happy temps, it will quiet down a little. All you can do is keep it as full as possible , as this helps it stay cold better and is more efficient.
I hope this helps some:)
Farmerbear
Aug 28, 2010 | Microwave Ovens
My freezer side GE Profile Performance refrigerator collects water at the bottom and freezes. I have to dig out and cclean the ice every 2-3 days. I turned off the water line , but it still does it. what...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 25, 2010 | Microwave Ovens
AMANA UPRIGHT FREEZER LEAKS WATER FROM THE DOOR
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jan 14, 2010 | KitchenAid Architect II KBHS109SSS...
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Dec 12, 2009 | Microwave Ovens
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
806 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
