Question about Car Audio & Video
What is Illumination - Car Audio & Video
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Illumination refers to the lights. If something is illuminated it is lit up, or has lights.
Posted on Mar 24, 2011
What is the fuse number for the dashboard lights on a 2007 Ford Focus 3 door hatchback?
Principles of Operation
The instrument cluster and panel illumination consists of dimmable and non-dimmable illumination components. The dimmable illumination is controlled by the instrument panel dimmer switch, which allows the brightness level of the backlights to be adjusted to the customer preferences. With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity. The headlamp switch backlighting consists of 2 constantly illuminated LED bulbs that are powered by separate circuits. Battery voltage is supplied to the first bulb when the ignition switch is in the RUN position. Battery voltage is supplied to the second bulb with the parking lamps ON. The non-dimmable illumination allows for full intensity dependant on the ignition switch position.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Instrument panel dimmer switch
  • Circuitry
  • Connector(s)
  • Headlamp switch
  • Illumination source(s)
  1. If an obvious cause for an observed or reported concern is found, correct he cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, verify the symptom and GO to Symptom Chart .
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The control illumination is inoperative
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test A .
  • The instrument cluster illumination is inoperative
  • Circuitry
  • Instrument cluster
  • Go To Pinpoint Test B .
  • The climate control panel illumination is inoperative
  • Circuitry
  • Climate control panel
  • Go To Pinpoint Test C .
  • The audio unit illumination is inoperative
  • Circuitry
  • Audio unit
  • Go To Pinpoint Test D .
  • The transmission control lever illumination is inoperative
  • Circuitry
  • Transmission control lever illumination bulb
  • Go To Pinpoint Test E .
  • The hazard warning switch illumination is inoperative
  • Circuitry
  • Hazard warning switch
  • Go To Pinpoint Test F .
  • The traction control switch illumination is inoperative
  • Circuitry
  • Traction control switch
  • Go To Pinpoint Test G .
  • The window control switch illumination is inoperative
  • Circuitry
  • Window control switch
  • VERIFY the operation of the window control switch in question. If the window control switch is inoperative, REFER to Section 501-11 . If the window control switch operates correctly, INSTALL the new window control switch in question. REFER to Section 501-11 .
  • The instrument panel illumination does not dim
  • Headlamp switch
  • Circuitry
  • Go To Pinpoint Test H .
Pinpoint Test B: The Instrument Cluster Illumination Is Inoperative
Normal Operation A variable pulse width modulated (PWM) voltage is supplied to the instrument cluster through circuit 29S-LA31 (OG/BU). The instrument cluster is grounded through circuit 91-GG14 (BK/OG).
    Possible Causes
  • circuit 29S-LA31 (OG/BU) open
  • circuit 91-GG14 (BK/OG) open
  • instrument cluster
PINPOINT TEST B: THE INSTRUMENT CLUSTER ILLUMINATION IS INOPERATIVE CAUTION: Use the correct probe adaptor(s) when making measurements. Failure to use the correct probe adaptor(s) may damage the connector.
Sep 24, 2017 | Ford Cars & Trucks
Electrical
do you mean all warning lights or illumination when main lights turned on ? if its the illumination have you a rheostat switch which dims/brightens dash illumination , see your drivers handbook for location
Apr 22, 2014 | 2006 Ford Bantam 1.3i
No illumination
If it works without illumination, it's ok.
Jan 18, 2014 | Breville Kitchen Appliances - Others
Dash lights do not work
Power is supplied to the instrument illumination by the "TAIL/ILLUM LIGHT" fuse, Fuse #4 (15 Amp) located in the dash fuse block under the left side of the dash. This fuse provides power for both the primary and secondary sides of the TAIL LIGHT relay. The Combination (Headlamp) switch provides a ground path for the primary circuit of the TAIL LIGHT relay. When the primary circuit is completed by the Combination switch, the secondary contacts close and provide power to the tail lamps as well as to all of the instrument illumination bulbs. The ground for the instrument illumination bulbs is a variable-resistance circuit which is controlled by the illumination controller. The final ground for both the combination switch and the illumination controller is Ground G302, located under the center console.
Dec 23, 2011 | 2001 Isuzu Rodeo
1991 alfa spider. No illumination in instrument cluster but all gauges, waring light etc work. fUSES GOOD
I'd approach solving this as follows:
* pull out the cluster and check all the illumination bulbs. Replace any that are faulty. You may already have done this. Trace the circuit to the cluster connector(s) to locate the +12v and GND.
* apply +12v to the circuit and verify that the bulbs do work.
* next, check the harness that plugs into the cluster. When the illumination is on, do you get +12v on the correct pin?
* The illumination is varied by a resistor or an electronic box, most likely in the circuit after the cluster, and before GND. Pull the illumination control and check
** the circuit between it and the cluster connector.
** the control and GND
* put the cluster back in and check that controller again. You should have +12v coming from the illumination circuit on the cluster. You should be able to safely ground this connection to test the illumination.
If this works, and the control is grounded, then the control is faulty.
SD
Sep 16, 2011 | 1988 Alfa Romeo Spider
Keyboard illumination
ok marty assuming that u r using vista and that this illumination has a support software try this go to the start menu and at the search area located at the bottom of the menu type keyboard illumination or something similar i am sure that this thing is software supported and some support software name will pop up from where u can get it working try it best of luck
Sep 09, 2009 | Toshiba Computers & Internet
Air conditioning and illumination does not work
I would say they used the illumination ckt for grounding the radio and now it probably either needs a headlight / illumination dimmer switch or Body Control Module. I hope this helps.
Thank You,
Roy
Aug 09, 2009 | 1999 Chevrolet Silverado 1500
Night time illumination on switch's and steering wheel.
This is by design. The cruise, lock and window switches do not light up on your Ranger. I thought they might until I checked a wiring diagram. The switches do not have an illumination circuit to them.
Jul 08, 2009 | 2000 Ford Ranger SuperCab
Wiring problem with cd player and lights on car
If the unit is turning off when you turn the headlights on, check that you haven't used the illumination wire as ground.
The illumination wire will normally measure as 0V compared to chassis ground. When you turn the headlights on it will go to 12V compared to ground. With the headligts off, if you measure your constant power and switched power (aka 'Accessories') lines against the illumination wire you'll measure 12V and everything will seem alright. However, if you turn the headlights on and then measure again (now that the illumination wire has gone from 0V to 12V) you'll measure 0V, since the voltage difference between the 12V constant/switched power and the 12V illumination wire is zero - they are both now at the same voltage and no current will flow.
Once you find (or install) the correct ground wire and you should be right.
Dec 01, 2008 | Toyota Corolla Cars & Trucks
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
