Question about Cameras
When i turn on my camers, the screen is black and it says card cover open when the cover is actaually closed please can you help???
    Problem Solver:
  • 5 Answers
Did you try another media card? If you only have the one media card see if your computer can read it,
Posted on Mar 24, 2011
Have an Olympus Stylus Tough -6000 digital camera and when I turn it on a message appears on the screen that says "card-cover Open" and it won't allow me to operate the camera. The problem is...
remove the batteries and the card from the camera and clean it with something smooth and dry ...after that reinsert the card in th ecamera several times until it is recognised..this happens when the card it is not proper inserted ..or something is meesing with the sensor that detects the cover position...so a gentle cleaning inside will help also..
Dec 21, 2010 | Cameras
Olympus FE-46 shows Card-cover open error. Cover is closed.
Hi, I have solved this problem in a Olympus Fe-20 camera. First of all, I will explain the facts of the problem. When closing the cover, inside the camera, there is a switch that get closed. This switch is like a door that opens or closes a electric contact. So when this switch is broken it does not join the contacts, so the camera thnks that the card cover is still open. Taking out some screws of the plastic tap of the touch screen, you will see, the touch screen fixed with a special conector. With a small screw driver take the black part up, and then you will manage to take out te touch screen. Then you have to take out the the board where the touch screen was fixed, taken out some screws , and disconneting the card from a similar conector than the one of the touch screen. So you can take out this board, and see that you have reach the main board of the camera. If you close the card cover, you can see in the main board the switch that opens/closes a contact due to the position of the cover. The switch has 4 welding points. You will have to take it out, by a tin solder. Then put a tin in the left down welding point and fix with a wire to the rigth up welding point. Fix the boarding card with its conector, fix the touch screen with its conector, and try to switch the camera on. If OK, fix everything up. If not, have a look at the contacts welded, that the problem is there. Hope to be helpfull.
Oct 26, 2010 | Olympus FE-46 Digital Camera
The screen on the camers does is just black and does not show the image how do i fix it. it is a powershot A20
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't correct the problem, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 06, 2010 | Canon PowerShot A20 Digital Camera
Camera on standby open lens cover
take off the lens cover?, the cover blocking the actual camera lense, this is preventing the startup of the camera or your getting a black screen window right, or slide the cover that over the lense across
Jun 23, 2009 | Nokia N72 Cellular Phone
Screen Is Black
there are two possible problem of your camera..1 may be the iris is not opening..try to look at inside of the lens you should see the iris will open when you turn off and on the the camera at the camera mode..if the iris in opening the 2nd problem maybe is the image sensor is deffective..in this case you have bring it to the service center....
Aug 29, 2008 | Samsung 1.5MP High-Definition Digital...
When i power on my camers the screen says card-cover open
the switch that controls the door may be going bad.. and would need repair.. but you can try to reset the camera or leave battery out of camera for a couple days
Jul 06, 2008 | Olympus Stylus 720 SW Digital Camera
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
May 23, 2008 | Olympus Stylus 790SW Digital Camera
Security camers not displaying on
Try going to that input and changing ntsc/pal or make sure your closed captions are off.
Nov 21, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My camera wont take the picture and screen is black
Be sure to fully charge your batteries if rechargeable - at least 14 hours. Check that your card door is closed good - it's common for the latch to break. There's a switch at the top of the door that has to close before it'll turn on.
Dec 08, 2006 | Canon PowerShot A75 Digital Camera
Cameras Logo
73 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
