Started to make a loud noise whilst spinnig every other process is ok any thoughts would be apreciated thanks.
    Sergeant:
  • 170 Answers
Sounds like jet? rear tub bearing;; this is the time to replace before more damage is caused. Good luck
Posted on Mar 24, 2011
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Why is my washing machine making a loud banging noise when spinnig?
wip the top off and have a look at the big stabilizer springs that hold the drum up if one is missing or broken off replace it,,,,if these springs brake or fall off the washer dose a grate dance around the floor done it?
Nov 24, 2010 | Indesit W 123 Front Load Washer
I'VE WF8550NGW, THE START/PAUSE BOTTON NOT WORKING while washing for the first time, during spinnig it was making loud noise n moving a lot. so i tried to pause, it dint so i switched off (power off...
did u level the machine before you started it with a level? if you did not then u would need to level the machine because this would throw off how the machine spins which also on a samsung would cause it to not to start up again. If your machine is 3-4 days old then it is also under warranty and you can easily call for them to come fix the machine. Please right back if you do not have the warranty on your machine and ill instruct you how to get to the technical manual located on the inside of the machine thanks again.
Rick
Nov 07, 2010 | Samsung Washing Machines
When our washer is spinnig it is makking a loud noise
your load is off balance, the basket assembly has come loose or the bearing needs to be replaced
May 01, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Very loud noise when spinning out of 1st cycle and now water leaking out of bottom
the main bearings have worn out and should be replaced soon as possible if left the drum will colapse as the bearing shatters could cause other damage to machine parts it will normally fail when the machine is under most load whilst high speed spinnig
Jan 16, 2010 | Washing Machines
Loud
This could be a bearing getting noisy in the transmission. But we have to try and pinpoint where the noise is coming from. And did it start suddenly? Or gradually get louder over a few weeks?
Jan 05, 2010 | Kenmore Washing Machines
When the car is started and while driving it is produceing a very loud whining noise. It gets louder when i accelerate. The noise is being compaired to a siren on a fire truck. What could be wromg??
It sounds as though your alternator bearing is about to fail. Take a long screwdriver and carefully place it on the center of the body of the alternator, away from the spinnig fan. Place your ear on the screwdriver handle and listen for any bearing growling sounds. This is most likely your problem.
Oct 08, 2009 | 2004 Dodge Stratus
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
