Question about Toshiba Office Equipment & Supplies
I am having difficulty in changing the toner bottle on a toshiba 3560 copier I opened the copier Pulled out the toner bottole about one half inch I wiggled and jiggled the bottel which eventually came out. I did nodt break any little plasti c parts, h owever I left a little white plstic slide valve, which is part of the old toner bottle I cannot remove the remaininig palsteic part Do not knowhow to instal a new toner bottle I can anticipate having difficulty pushing the sidle tray back in i have spent nearlyi four hours lookig for n answer from you last evening i was left hanging, no response no answer
  • MICHAEL WEINMAYR Mar 24, 2011
    I NEED HELP IN REPLACING T HE TONER BOTTLE ON A TOSHIBA 3560 COOPIER
    I OPENED THE COPIER
    PULLED OUT THE TONER BOTTOLE ABOUT ½?
    I WIGGLED AND JIGGLED THE BOTTEL WHICH EVENTUALLY CAME OUT.
    I DID NODT BREAK ANY LITTLE PLASTI C PARTS, H OWEVER
    I LEFT A LITTLE WHITE PLSTIC SLIDE VALVE, WHICH IS PART OF THE OLD TONER BOTTLE
    I CANNOT REMOVE THE REMAININIG PALSTEIC PART
    DO NOT KNOWHOW TO INSTAL A NEW TONER BOTTLE
    I CCCCCCAN ANTICIIIIIIPATAE HAVING DIFFIICULTY PUSHING THE SIDLE TRY BACK IN
  • 3,530 Answers
Welcome to Fixya
Replacing the toner bottle is pretty much common for all copiers. Here's my experience when i replaced mine. Please see procedure below:
1. Twist or unlock the empty toner bottle in the machine. The empty toner bottle will be held in place by some method in the copier. Usually there is a tab that locks the toner into place, while some toner bottles require you to twist or turn the toner bottle to remove it. The empty toner bottle can either be recycled or thrown out.
2. Prepare the new toner bottle. You may need to remove protective tape or tabs before you can install the new toner bottle. Make sure you fully prepare the new toner before attempting to install it.
3. Install the new toner bottle and secure it into place. Toner bottles usually slide into place and are then secured by the same method as described in step 1. Yours may have a securing tab or may need to be twisted so that it is locked and secured into the copier.
4. Clean up any spilled toner. As careful as you may be, spilling toner is a common event. Toner is hard to clean up and can ruin clothes, carpeting and make your copier look dirty. Using a slightly damp cloth will make cleaning up any spilled toner relatively easy. If there is a large amount of spilled toner, use a small vacuum cleaner.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Mar 24, 2011
    President:
  • Toshiba Master
  • 2,246 Answers
A better way is contact toshiba service center, they will solve the problem
How do i get rid of the call service message
pull the toner and developericon1.png (they come out as one unit unless you delibrately seperate them) out of the top of the printer. Open the side door on the print and remove the waste toner bottle. You'll see a gray button above where the bottle was. Push the button and pull the drum out about a half and inch. Push back in firmly until it clicks. Reinstall bottle and reinstall toner and developer. Should work from there, but you may have to power off, then power on.
Mar 28, 2014 | Kyocera FS-4000DN Laser Printer
My toshiba 3560 is no print how to solution plz help me
HHmmmm. many possible causes of that sir. the Developer reach the copy limit. the corona wire is cut off. the high voltage maybe filled with toner need to clean that. or the exposure lamp is busted. Good luck in hunting Sir.
Apr 17, 2013 | Toshiba T-3560 T3560 Genuine Copier Toner...
After empying the waste toner bottle, the same waste toner bottle error still reigns on the copier screen.
The copier uses a photo sensor to determine when to replace the bottle. If the inside of the bottle is covered with toner, it thinks the bottle is still full. There should be a projection on the back of the bottle that fits into the sensor. You can try to clean the inside of the projection, but don't use any kind of liquid, use a dry cloth. You may have to buy another bottle. New ones should come with the toner. dood luck.
Sep 28, 2012 | Ricoh Aficio 2035 Copier
Disposed of used toner?
open the front door you will see a plastic bottle take it out and dispose of the toner in the bottle clean the bottle and wash out with soap and water to get rid of all the waste toner the ideal sinareo is to purchase a new bottle
Mar 21, 2011 | Toshiba e-STUDIO 352 Black and White...
How to put in the Toner
I would try this first... Leave the toner bottle out and close the toner door & let the copier come to ready. Then the toner bottle holder should be in home postion and it should be easier to install a new toner... Good Luck
Apr 20, 2010 | Minolta DiALTA Di183 Copier
Waste toner container replacement
Yes you can. But there is a window at the top of the bottle . There is a sensor that looks through that window to sense toner in it. It is a small area about a half inch high and quarter inch wide that bulged out of the top of the bottle.
Poke a hole in it, clean it with a q tip and reseal the opening you make .
That should do it.
Jul 01, 2009 | Xerox WorkCentre M-24 Color Copier
I need to change the toner to my canon super g-3 copier, How do I remove the old one?
Have you adde the new toner in to the copier and can noy get the spent toner bottle OFF, right? Once you have locked the toner bottle in, you have to pull the Blue lever on the right bottom side of the toner bottle. That is pulled to the right to allow the toner to feed into the hopper. Once the toner is empited from the bottle, you have to push the Blue lever back to the left and push a little harder when it stops. This will release the two claws that hold the bottle locked in. You should be able to tilt the toner bottle up and to the left and then slide the toner bottle to the right and remove the toner bottle. If you can not get the toner bottle off, leave it till a service person comes or somebody else, don't force it, IT WILL MAKE A VERY, VERY, VERY BIG MESS...... The copier will work with it attached. Good Luck... I wouldn't ware white.....
Jan 19, 2009 | Canon imageRUNNER 5000 Copier
Toner bag
usuaslly when you change bag you have to go into service mode and reset counters..
Nov 17, 2008 | Toshiba e-Studio163 Copier
I replaced the toner in the Toshiba 3560 copier and after replacing the toner the machine still says to add toner. Any suggestions?
You may have a clog going into the developer. If you can get the developer out you can then vacuum it out.
Jul 22, 2008 | Toshiba Office Equipment & Supplies
Our Panasonic DP-4510 says "Replace the Toner Waste Container." However, we cannot find where to do that -- and the machine's manual makes no mention of it!
If the front panel is rear side of uou. Then Right_bottom side serfface have the waste bottol; if you open the flexiable cover. You found a plastic bottol, no electronics attech with it. You pulled it out; empty it out side the room/office. Then fix it back their location. Maight be some model have counter inside softwere. in that case reset the counter by softwere.
May 21, 2008 | Panasonic Office Equipment & Supplies
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
