Question about Nintendo Wii Console
The sync button on my wii console is stuck and I can't sync any of my wiimotes thus rendering me unable to play a game. How do I fix it?
  • 112 Answers
If the red button still pops out, but the button inside is stuck, you could give the red button a few solid taps with the tip of a finger. If it's the red button that's stuck and won't pop out, take a piece of tape, stick it to the button, then pull the tape off in a fast motion.
Posted on Mar 24, 2011
Wii remote four lights solid
Sounds like it needs to be re synced with the system, Easy place batteries in Wiimote and turn on console press the red sync button in the back of the Wiimote and press the red sync button on the console it is now synced. If this fails it could be that the Wiimote has failed, if Wiimote had failed within warranty period of 90days from date of purchase return for repair or replacement if it is after warranty period discard and replace with a new Wiimote.
Jan 12, 2013 | Nintendo Wii Console
We tried to reset the sync buttons and the blue lights on the remote blink repeatedly but it still does not communicate with the game
Try removing and reinstalling the batteries from the wiimote and the unplug the wii power cord at the outlet end for a couple minutes. I had that problem once and this seemed to fix it.
Mar 07, 2011 | Nintendo Wii Console
I cannot connect to wii console with remotes
In case you don't know how to do this: 1) Open the small door in the front of the Wii, and next to the SD card slot is a red sync button. 2) Take the back off your Wiimote and on the button right is a small red button. 3) Press the button on the Wiimote then the button on the Wii, this should sync the controllers.
Now sometimes this doesn't work. It happens to almost everyone. All of a sudden the Wiimotes just loose to sync, but after a long period of time they start working again. From what I know there is nothing you can do about this. But here are some things that you can try:
1) Unplug your Wii then plug it back in. 2) Try new batteries in your Wiimotes. 3) Keep trying to sync the Wiimotes. 4) Try to sync them in someone else's Wii, and then yours.
Sep 19, 2010 | Nintendo Wii Console
The wii remotes will not hook up to our game console how can i connect it?
To setup your Wii Controllers. Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries.
Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu.
Open the front door on the front of the console to reveal the SD card input and the "Sync" button.
Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash.
Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect.
Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on.
Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
Feb 15, 2010 | Nintendo Wii Console
I cannot get a cursor on the menu screen of my wii. i can access the menu screen, but I can't select the game.
Sounds like you haven't syncronized you wiimote to your console. - Turn on Wii - Press the red sync button behind hatch on wii front. - Press red sync button behing batterry hatch on wiimote. That should be the hard part. Possibly you can be required to access. To do the pressing of button 1 & 2 at the same time to reconnect. But red buttons are for initial sync.
Jan 08, 2010 | Nintendo Wii Console
Even with new batteries in the wii remote,when i turn on the console,the screen comes up that says "press A button",,,,but nothing happens,the sensor bar is firmly secure but still nothing happens,its very...
Is it a Wii game? Gamecube games aren't compatible with Wiimotes. Otherwise, Check the lights on the Wiimote, Are they on? If not, You could have a battery problem, Or your Wiimote could be broken. Make sure the Wiimotes are connected, See your manual for info on how to Sync.
Oct 27, 2009 | Nintendo Wii Console
Wii Remote doesn't work
1. Make sure that your batteries are in correctly. See working Wiimote for reference.
2. When you sync the Wiimote, press the red button in the battery compartment and immediately there after, press red sync button in the Wii Console front panel (where the SD card goes between the Eject and Reset buttons).
3. Power off Wii console completely and restart.
4. Press any button on the Wiimote to activate.
5. If the above steps don't work, you may want to return it to the store for a replacement.
Apr 12, 2009 | Nintendo Wii Remote Controller
Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
Jan 01, 2009 | Nintendo Wii Console
Wii remote
Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
Hope this helps
LesPix
Feb 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
594 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
