Left and right click on the touch pad working but double clicking on the touch pad not working
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 97 Answers
You may need to update your touchpad drivers to the latest version to fix this problem. What is your laptop model?
Posted on Mar 24, 2011
How do i turn on touch pad
You probably have a Synaptics Touchpad. What you have to do is look for the Synaptics logo(it's like a white circle on a red background) in your status bar(lower right corner of the scree, neer the clock). Double click that icon. A window called Mouse properties appears. The last tab is Device settings that also has the Synaptics Icon. If you click it you should see a list of all Synaptics devices on your laptop. Since you only have one you will only have one item in the list. Double click that item and a new Properties window will open. You have a list on the left side of that window. Select tapping and make sure Enable tapping is Checked. That should be it.Good Luck!
Nov 16, 2011 | Compaq (153515-001) Touch Pad
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
When i click on the folders with the double click on touchpad then it don't open
setting your touch pad first at control panel. or you can right click touch pad icon on right bottom of your ask bar and chose properties.
setting goes there. and enable double click.
Mar 06, 2011 | HP Pavilion dv6-1030us Notebook
When trying to select something by double tapping nothing happens
try to go to
Start
control panel
system
device manager
look on the part represent your touch pad then right click. look on the properties and then driver and then rol up driver..
check this first..
Oct 31, 2009 | Computers & Internet
I cannot enable the touchpad settings.
Hi there...
First of all has the touch pad ever worked?
Lets give this a try, go to the START button and left click, look for the CONTROL PANEL and double click on it.
When the Control Panel opens look for the MOUSE and double click to open page, on the tabs look for ULTRANAV, you should see a check mark box, ensure that there is a check mark under the Enable Touch Pad, hit the APPLY and OK.
Voila, your touch pad should start working.
Aug 29, 2009 | IBM ThinkPad R40 2722 Notebook
Touch pad is moving but click the folder but not working
go to the control panel and open mouse properties.  you should find an option there to enable the touchpad click.
Jan 29, 2009 | Acer Aspire 5610-4648 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
