Question about Smeg SE210X/1 Stainless Steel Electric Single Oven
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Posted on Mar 06, 2014
5 Suggested Answers
  • 1462 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
i suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Posted on Jul 18, 2008
  • 30 Answers
SOURCE: grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Posted on Aug 21, 2009
SOURCE: Ariston TC720 electric double oven.just had power
Hi
I have exactly the same problem, did you have any joy sorting??
Posted on Mar 31, 2010
SOURCE: Re: Westinghouse Wall Oven/Grill .Timer
Hi, well i tell you these units are a pain to get into the area where the wiring hooks onto the module... also there were a few variants, so the timer modules were different, this means one would have to have a service manual of the exact make model to even be able to source the bits, in the first place. This is the BIG problem, obtaining the exact parts.
My recommendation is to save yourself skinned knuckles and time and money, and call an an electrician for that "Quote'.
Posted on Mar 23, 2011
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
Thermador CM301U Microwave cook smart, self clean and proof buttons all make the display light up as normal, but probe, convection, bake, broil and roast do not. I can hear the beep but nothing on the...
there are two boards in the oven and i would think that it is the one on the left called the secondary . if you remove the display panel you will find the tech sheet and this should help diag the problem . thermador does use fault code's and if any have displayed / in the tech sheet you will be able to tell whats going on or in this case what isn't .. mm hope this helps .. feed back pls .
Nov 29, 2010 | Thermador CM301U Electric Single Oven
Power outageoven says stop the little button seems jammed wont push in any way around this?
i have the same problem. the oven was installed in my new house before i moved in, the display just says stop an the button doesnt click or anything? did you manage to find out what was wrong?
thank you
Jul 01, 2010 | Whirlpool AKZ159IX Oven
Oven door wont unlock/open
E1 and F1 error code indicates a faulty ERC board. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing. Gain access inside the control panel.Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.Turn the power back on. Wait for an hour to see if the code comes back (usually accompanied by a beeping sound). If code comes back, replace the ERC. If it does not, replace the touch pad.
Thank you !!
Jun 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
No Power, DEAD
I would pull the stove back, first to check the plug, and then, the cord. If all is well, and breakers are good, you might need to call, then
Jun 17, 2008 | Whirlpool AKZ159IX Oven
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
May 15, 2008 | Whirlpool RBD275PD Electric Double Oven
Whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
May 08, 2008 | Ovens
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Smeg SE210X/1 Stainless Steel Electric Single Oven Logo
207 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
