Need a fan for a laser 73 - iam in oregon fan dose not work ____ the fan on the back about what is the price
    Genius:
  • 1,196 Answers
I will advice you order for the fan online, you can order for it at ebay.com, the price should range between $10 - $15. This depends on when you are buying it.
Posted on Mar 24, 2011
How do I fix the fan?
The fan's power comes from a multi output transformer.
Either the fan is burned out or the transformer is burned out or the fans moles plug is not plugged in properly.A simple voltage spike or brownout can take out the transformers.
Feb 27, 2015 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73 has EE8 code after we had an electrical outage. The blower fan is not stuck. Could the loss of power damage the fan motorr? Where do we purchase a new fan motor?
Probably wasn't so much the loss of electric power, as it was perhaps, a surge when it came back on that could have damaged the fan motor
You should be able purchase a new fan motor from the dealer your bought the heater from. Or if that's not an option, go to http://www.rinnai.us/ and search for a authorized dealer close to you. That way, you can be sure you're getting an OEM part.
Hope this helps resolve your problem.
Feb 26, 2011 | Rinnai Toyostove Direct Vent Heater:...
It saying ee8 blower on da laser 73
EE-8 is for a blower motor malfunction. It could be due to carbon build up on the exhaust fan blades. Remove the front cover of the heater. Now locate the blower. There is a black rubber boot that goes from the bottom of the heater to the blower. Remove that boot. Use your finger or a pencil or whatever to reach in the hole and turn the fan blades. You may here a crunching sound from the carbon breaking up. Turn it until it frees up. If it turned freely to start with, you probably need a new blower motor. If it was hard to turn and you free it up, you will probably be OK.Let me know what you find. I have a used blower for a Laser 72 that should work for your Laser 73.
Dec 31, 2010 | Rinnai Toyostove Direct Vent Heater:...
Error reading ee8
EE 8 is for a blower motor problem. It could be the sensor that checks the blower speed or it could be the blower not running. If the blower is running, the sensor is bad and you will need a new blower. If it isn't running then you may be able to fix it. Sometimes on the Laser 73, soot and carbon will build up on the exhaust fan blades. Remove the fresh air hose, that is the rubber on the back, and look for the fan blades. If you can see them turn the heater on and see if they are turning. If not turn the heater off and try to turn them with your finger. If you hear a noise like something rubbing when you turn it or feel some resistance, keep turning it until the noise stops or it frees up. Now turn it on again and see if the fan runs. If you don't have anywhere local to get parts I can get them for you. You can contact me at nitensheaterservice@earthlink.net I may also have a used blower that will work.
Nov 14, 2010 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 fire will start but the circulation fan will not start. will eventually overheat and then shut down with EE 2 error. Whats up?
Because you have the EE2 error I would say there is nothing wrong with the circ fan. Your are either having a problem with fuel flow or the igniter. Feel around the two red wires when you try to start the heater. If they get hot you have a fuel problem. If you also hear a thumbing noise you have a fuel problem.
Tom
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater:...
Need to reset temperature control on my toyostove laser 73
I'm not sure if I'm answering the question right, but the reset light should reset when the heater cools down. If not you may have a problem a circuit board or a bad temperature sensor or loose wire. You should find out why the heater overheated. It could be a dirty fan or fan cage or something else blocking the air flow.
Jun 30, 2010 | Rinnai Toyostove Direct Vent Heater:...
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Dumb Question
Mike,
NO, Rinnai and Toyotomi (Laser) are not the same. A simple Google search would make that clear. Now, a new blower motor with case for a Laser 73 comes complete. Fans, motor and gasket all put together, ready to plug in and go.
You would be better off contacting a local dealer for your parts. NO authorized Toyotomi dealer is supposed to sell parts over the internet. A Toyotomi dealership is a valved item. It is meant to help sell and service the Toyotomi product in the dealers local area. It is a great help for someone to be able to call his local dealer and have that guy come right over and help you out.
Saty warm,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Mar 06, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73
A manual can be found online by googling Toyostove 73 and owners manual or manual. I use it often. It is at on the rural energy website.
Jan 13, 2008 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
