Question about LG GT540 Cell Phone
I have an sd card in my lg gt540 phone, but it keeps notifying me that the sd card has been removed... I've heard from here that it's because the sd card slot is damaged, but how do we fix THAT?
  • 492 Answers
You cannot fix the slot unless you are very experienced in small electronics work and can take apart the phone. It is not an easy repair. If the unit is still under warranty you might call your service provider and ask what your options might be.
Posted on Mar 24, 2011
How to format a sd card for lg optimus gt540
Go to Settings->SD Card & Phone storage->Unmount SD cardNow click on Format SD card.
Cheers,Mr.Maduraikaran.
Aug 25, 2011 | LG GT540 Cell Phone
On formatting a SD card will all applications will be deleted in GT540?
If you format your SD card,only those application which have been downloaded by you externally and saved on the memory card will be deleted. The applications which were there on your phone by default and those which are saved in phone memory will not be affected.
Thanks and have a nice day.
Aug 17, 2011 | LG GT540 Cell Phone
When i turn on my LG GT540, it doesn't proceed to the home screen, it only remain in its welcome mode, the "android" part. I tried to remove the battery and recharge it again but nothing...
If there is SD memory card inside the phone, swicth of the phone and remove the memory card. after then switch it on.
If the problem continues then you will need to flash the phone.
Since you do not have the cord and the software to flash the phone , it is better you take it to a repairer and pay a token of amount.
Thanks for your patronage.
Jun 09, 2011 | LG GT540 Cell Phone
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
Hi, i m using LG GT540 mobile. The camera won't work. it ask the SD card. After i put the card, when i go to the camera, its not open. it just blink only. or sometime the message was appeared "sd card...
Sometime this occurs due to the format issue. Did you format the SDcard using Win32 or NTFS? those two are likely the culprits.
If not, it is time to replace the card.
Mar 04, 2011 | LG GT540 Cell Phone
How can i install applications in LG GT540 (Optimus - Android 1.6) SD card?
How can i intall game or apps on my lg gt540? Please must answer
Nov 25, 2010 | LG GT540 Cell Phone
How can i install application in sd card in lg gt540...
if you insert the card into the pc and try from that source and you are unable , maybe it can be installed like that just on the phone, some phone dont give the option to install on the micro sd just on internal memory
Nov 22, 2010 | LG GT540 Cell Phone
I can't connect my LG GT540 to Lg OSP some connection error, on the other hand i able to connect my phone on LG PC Suite. How can i put USB mode in PC suite mode. i cant find the settings.
The PC suite is found on your SD card. Connect the usb cable to your phone and when prompted enable SD card. Then select on your PC computer and you will see another drive being that of the SD card. Open the olders and you will see the install option for the suite. Install and follow the prompts.
Sep 24, 2010 | LG GT540 Cell Phone
Lg gt540 micro sd card won't open on my pc????????
you have to install your lgpc suite first to your computer if you can not do it directly remove the memry card 2 gb which is free when you bought it then removed it then connect it ti card reader and from it down load the lgpcsuite from your memory card to your computer then put your memory card to your cellphone then connect it thru usb then mount it or allowing your sd card to mount to your computer see the usb connection above the screen drag it down and youll se the word mount click it and then proceed to you laptop and click the lg pc suite and it is done
Sep 09, 2010 | LG GT540 Cell Phone
LG GT540 Cell Phone Logo
358 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
