Question about Refrigerators
The bottom fridge compartment is not cold - Refrigerators
  • 96 Answers
Evaporator fan is not working or the refrigerator damper is stuck closed or you have a defrost circuitry problem and the evaporator is froze up
Posted on Mar 24, 2011
My Danby refrigerator shows a lot of temp variance. A thermometer on the top shelf shows 40 degrees, lower shows 32, is this normal?
if the door has been opened or used for a number of times ,that variation will be around normal
the system works like this
the fridge cools air from the bottom up as cold air falls to the bottom of the fridge
if the door is not being opened ( over night) the whole compartment becomes to the same temperature as set by the thermostat and that is when the fridge cuts of
Now if the door seals are leaking cold air out at the bottom then the whole compartment will never get to the same temperature ( your variation)
similarly if the door is constantly being opened , the cold air at the top of the compartment replaces the cold air at the bottom that has flowed out onto the floor on opening the door (again your variation)
so you have to possible items to check
1 are the door seals in top condition and 2 is the door being opened too much in short periods of time
Jul 18, 2015 | Danby Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
My refrezrator is not cool properly lg
Most fridges only cool the freezer compartment and the cold air then flows into the fridge section. It could be that the hole to the fridge from the freezer is frosted solid and no cold air can get through, if so, use a hair dryer to melt the frost and open the hole. It is usually near the bottom of the compartment.
Apr 05, 2014 | Home
Two year old Fridge with bottom freezer and french door upper. Cold freezer and a warm fridge how can we correct this?
First thing to check would be the fan in the freezer compartment, it circulates the cold air up to the refrigerator compartment
Jun 27, 2011 | Amana Refrigerators
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Fridge compartment not cold
I would like to get the temperatures in freezer and bottom freezer Profiles are somewhat different than most. We have either a defrost problem or the electronic air damper is stuck shut or defective. I will try to find your model number but it just will not be as helpful as using the correct model. Anyway I am here and ready when you are, Sea Breeze
Apr 17, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Maytag fridge not cold
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Mar 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
