Question about Dopod D810 Smartphone
Greetings. The dopod 810's below-screen navigation buttons had stopped working so I sprayed them with WD40 (it worked well on the laptop keyboard!). Result: nav buttons show some life but the touchscreen dies! The screen display is working but the touch function is dead. What's happening here?
  • rupiahville Mar 24, 2011
    are you saying i need to open it up and clean the connection with a soft brush?
  • 64 Answers
You disassemble your device before you spry wd40.. if not you much open your unit because there some lick over the connection of touchscreen connector... you much clean by soft brush...
Posted on Mar 24, 2011
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
Greetings. The dopod d810's below-screen navigation buttons had stopped working so I sprayed them with WD40. After that the navigation buttons worked but the touchscreen didn't ! The screen display is...
w40 is not a good thing to use it leaves an oily residue on stuff that's way its used to clean and remove rust and lubricate rusted nuts. you now need to remove all the wd40 from the device. should only use electrical switch cleaner as it cleans and evaporates. when clean it may work again but there is no telling if it has damaged anything. screens don't like grease inside them. try spraying cheap deodorant on it sometimes it will remove the grease but remove the battery .
Feb 20, 2018 | Dopod D810 Smartphone
My wing work fine when its on but it is hard to turn on i allway have to play with the button but now it just stop workin for me
spray some WD40 onto the affected button, and make sure the battery is removed and phone is OFF. After u spray WD40, push the button gently until the sprayed solution evaporates. Good luck.
Jan 05, 2011 | T-Mobile Wing™ Smartphone
Pcsuit
Download and install Activesync into your pc. You can download it free at http://www.pocketpc-freeware.net/dopod-d810-device-594/activesync-download-240.html
Mar 29, 2010 | Dopod D810 Smartphone
Keys not working on mini laptop advent 4490, only few working on right hand side of keyboard
Look to see if it has a port where you can plug in a regular key boad usually on the back or side.. If a regular keey board works then the MiniKeyboard on the laptop has become dirty and corroded. That would require you take it apart and replace or clean it. i have had luck spraying it with a light pass of WD40 that will absorbe moisture.
Nov 08, 2009 | Computers & Internet
The enter key of my laptop sudden stopping working?
I would try getting some compressed air. Sometimes called canned air.
1915830-4u4zdtshcqwq1u3gjz1kqwnk-5-0.jpg Blow inside the keyboard, under and around the enter button and see if it helps. Do not hold the can upside down or sideways while spraying! It shoots out as ice and can hurt things further!
Apr 02, 2009 | Acer Aspire 3680 Laptop
Casio ctk 810 keyboards volume control problem
Yes spray some contact cleaner into the switch while unit is off. move it back and forth spray a little move. dp this a few times. this will clean it up and it should work better. Get this stuff a Radio Shack. $8.00 a can. I use this stuff on all kinds of electronic;s. Like a stiskiy keyboard button, so forth.
Good luck DFD
Dec 16, 2008 | Casio CTK810 61 Key Keyboard
Key not working
Try taking some WD40 and spray the entire keyboard while pressing the buttons and then clean it up and try it again.
Mark
Oct 14, 2008 | Texas Instruments TI-83 Plus Calculator
Dopod 838 pro touchscreen not working
Have you tried a hard reset?
(Hold in the power button why pressing the stylus in the reset button on the bottom of the phone)
Jan 29, 2008 | HTC TyTN Smartphone
D pad keys do not work
the dopod 838 is a real pain in that all the screws loosen themselves up. just tighten them up and they should start working again
Jan 23, 2008 | Dopod 838 Smartphone
Dopod D810 Smartphone Logo
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
