Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
My Mcculloch chain saw has fire at spark plug gap. The plug is wet after trying to start it. Gas lines are clear. I can feel compression with my finger over the plug hole while pulling the rope. It was running fine last time I used it, drained tank & ran it till it stopped running. It just does not even act like it will start, can it be the reed valve stuck? Ready to buy a new saw. Stan
    Sergeant:
  • 259 Answers
It sounds like the compression is too low to fire the engine. Try starting it off choke with the throttle trigger open all the way.
Posted on Mar 24, 2011
  • dambunnies
    dambunnies Feb 19, 2015
    Try removing muffler . Should be 2 little screws. Inside is a small peice of screen call a spark suppresser. Take it out and see if your saw starts right up. If that works go get yourself a new one for 1.29. If they get blocked your saw won't run or won't idle
  • dambunnies
    The screen keeps from shooting out sparks out muffler while your in the woods if you mix your gas a little to rich they will get plugged up and foul out your saw.
Mcculloch eager beaver chain saw
Hi Mike firstly check the air filter is clear and if so try putting some fresh gas where the spark plug goes into the block. If it fires its the gaskets on the carb. If it doesn't it's the gaskets on the block and it wont fire due to the compression being at fault.
Oct 20, 2013 | McCulloch Garden
How to test the coil pack on a chain saw
Yes. I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 13, 2017 | McCulloch Garden
Saw will not run or start...set ignition module gap, disconnected kill switch wire because there was no spark...Put in new spark plug, got spark..Primed for gas and set choke as per instructions...Would...
Often the cause is a failed fuel pump diaphram. Rebuild the carb... kits about $20. The diaphram works from engine vacuum pulses. Also the little flap type check valves go bad... the ethanol in gas doesn't help this problem...
Sep 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw will not fire. has spark at plug and compression is 130 will not fire even with starter fluid
If there is fuel to the plug, and a good spark it should fire, all i can think of is the ignition timing is out due to a sheared flywheel key.
Jun 11, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Is there a reset button for this chain saw? I was using it the other day and it was fine but today I can't get it on. Thanks!! ~Dawn
No reset button. Remove the spark plug and test for spark--it should be blue and snappy with a fresh plug gapped at 0.020". If nothing, the entire engine case must be removed to troubleshoot an ignition problem. If the spark plug sparks, but it looks wet, try pulling the throttle wide open (with the spark plug out), no choke, and pull the engine through smartly several times to expel the excess fuel. Check the air cleaner to make sure it is not plugged. Hope some of this helps!
Jan 17, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Will not start has 60 psi compression plug firing has gas model 50 new coil good spark plug
When I have a problem starting a saw this is what I do.
  • Remove the spark plug and pour 5 ml (one teaspoonful) of fuel into the opening
  • Dip the end of the sparkplug in fuel so the spark gap is wet
  • Replace the sparkplug and try to start the saw
The fuel that you poured in should ignite and may be enough to cause the saw to start. You may need to repeat the operation 2 or 3 times. Do not be tempted to put in too much feul as it will only flood the saw.
If the saw was left away with fuel in the carburettor for a few months the fuel may have formed a gel in the jets of the carburettor. If the above method doesn't solve the problem you'll need to have a mechanic strip down the carburettor and clean the jets.
Jan 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
After starting and operating the chainsaw for a short time, it dies and I can't get it started again. Suggestions?
Engines require 3 things. Spark, compression and fuel. And chainsaw need 2-cycle oil mixed with the gas.
Assuming you have the right oil-gas mixture and a fresh batch of gas, and you didn't leave old gas in the saw all summer long since last November.
-Take off the dirty air filter and see if saw starts without filter. Do not run without putting in new filter.
-Check exhaust port for mud dobber home or screen clogged with carbon and dirt
-See if saw fires up after squirting WD-40 directly into carburetor
-Check gas line >>> pull gas line loose and see if gas flows out of tank to carburetor
-Take out spark plug > put finger over spark hole and pull cord >> do you feel suction that says you got compression?
-Put spark wire back on spark plug >>> hold spark plug so threads touch bare metal part of spark plug hole >>> pull starter cord and see if spark shows between plug and saw >>> suggest you not hold metal part of spark plug while pulling cord [you'll understand why]
-If spark plug shows spark, then your saw has spark ... so put in new plug and start fresh.
If your saw has compression, spark, and fuel it should start unless carburetor is gummed up because gas was left in tank.
Here is the final trick. Start the saw while spraying WD-40 directly into carburetor and see if you can keep it going with the WD-40. This might take a helper. If this does not work, then carburetor is bad or gas line is clogged at carburetor. Time to take it to the shop.
Oct 06, 2010 | McCulloch Garden
I have a McCulloch MS1636NAV chain saw. The engine starts with the choke pulled out. When I push the choke in the saw dies. I've changed the spark plug, replaced the air filter. changed the gas, 40:1.
Its either sucking air in throgh a loose connection in the fuel line or the carb is stopped up. Take it apart very easy so you don't rip any gaskets, and clean evertthing with a can of compressed air blow all the tubes out real good. You may have to get a carb kit it that does not work.
But that sounds like what it is, running out of gas when you let more air to it.
Oct 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
Chain saw won't start
The end of the plug where you are looking for the spark needs to be touching the head while you pull the chord. It must be grounded...
May 22, 2009 | Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
161 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
