Question about Dell Latitude D510 Notebook
Every time I move my laptop a little bit, lines appear along the bottom of the screen. Also, sometimes the screen shifts when I'm using the mouse ever since those lines began appearing. What are possible causes of this, and is it worth trying to repair or would it be cheaper to begin looking for a new laptop?
    Problem Solver:
  • 6 Answers
Well this could be several things first, I have seen this before in a mac book lines would appear on the screen if I moved the monitor a tad. I think it would be a safe bet that there is a short in your monitor and screen replacements are not easy but can be done. Usually costs 100 or less In my opinion you can get a really nice upgrade from your Dell for about 3 to 400 dollars
Posted on Mar 24, 2011
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
Hi, I have Windows 7, 64 bit, IE8. When I watch youtube videos the slider bar disappears. I see it for a second then it reclines. I am talking about the pause, mute button, time of video etc., along...
The bar will dissapear away from the screen if you do not move the mouse, try moving the curser to the bottom of the screen and see if that will bring it back
Mar 18, 2011 | Toshiba Satellite A60 Notebook
VAIO laptop cursor moves by itself
Sometimes the surface the mouse is on can make the curs or seem to have mind of its own. Does it behave this way all the time or just here and there.?
Mar 20, 2009 | Sony VAIO VGN-C140G/B Notebook
1 yr & 4 wks old, bottom 2/3 of screen fuzz of lines
A couple of things that you might try.
1. Try changing the screen resolution - control panel - display - settings
Mar 11, 2009 | HP Pavilion dv9000z Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Monitor blurry or black
The problem could be with the LCD or the Video chipset. Either repair is expensive. I would figure about $150 in labor plus part cost. You can try ebay to get an idea of the part cost.
At 4 years I would be leaning towards purchasing a new laptop.
Dec 30, 2007 | IBM ThinkPad R40 2897 Notebook
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
White line
you have a shifted picture upwards the white line is the overlaped picture. Try accessingthe service menu and shift the picture down. Patrick
Jun 18, 2007 | Daewoo DSC-30W60N 30" TV
Dell Latitude D510 Notebook Logo
63 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
