Question about Motorola Mobility RAZR V3
Getting error msg on screen: Your memory card has been removed.
  • Donald Tucker Mar 24, 2011
    Does the card work in another RAZR? If it does the pins may be crushed or broken in the unit. This type of physical damage is sometimes repairable but there is no guarantee.
  • 40 Answers
Looks like a bad contact thing - remove the memory card and clean the contacts, both in the phone and on the memory card. Use some alcohol (not beer! 96% ethanol or at least vodka). If no alcohol is present you can try to rub the contacts SLIGHTLY with the rubber. Please do go with extreme care because it's very easy to break the contacts inside the phone!
Posted on Mar 24, 2011
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
Jun 20, 2016 | OKI C Office Equipment & Supplies
My memory card getting automatically removed from the phone giving error msg. uasafe to remove memory card withou selecting "remove mem. card" first......... autometically
hmm...reset ur mobile (w/o mmc) and after that..switch off fone,insert memory card and start.. <even i had same prob but now solved >
Jun 15, 2010 | Nokia N73 Cellular Phone
Samsung sch-r451c camera error 101 receiving this message have only had teh phone for one month, solution?
I had this same issue. I turned my phone off and back on and it worked. But i also called straight talk. they had me to remove the battery. replace it. dial 22890 to program it. it now works.
May 26, 2010 | Samsung Lands Phones
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Setup was unable to verify drive C:.
hi ;
this sems to be a memory problem;
in bios , try to decrease the memory for your card to resrve a memory space for the installation program,
if this does not work , it might be your VGA card.
Mar 11, 2009 | Computers & Internet
MEMORY CARD ERROR
Camera is not recognizing any memory card. The issue is with the camera electronics and not the cards.
Jun 20, 2017 | Sharp Viewcam VL-NZ150U Mini DV Digital...
Low memory msg
Happened to my n73 too. What you have to do is format the phone memory. Back up all memory on the phone to the memory card first before you do so.
To format:
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. :)
Jul 27, 2008 | Nokia N73 Cellular Phone
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
'This card cannot be used' error msg
If the correct memory is compact flash, many small fragile pins are in the socket.
If one or more of these pins was bent by the incorrect module,
then the correct memory cannot work again until the pin/pins
have been repaired.
Alternate soluton:
You might try removing all the batteries from the camera and
letting it sit for long enough to clear any temporary memory.
Don't forget any small button cell that might back up temporary
memory.
If the connectors are not damaged, the camera might be reset on a cold start up.
Feb 16, 2008 | Nikon Coolpix S51c Digital Camera
Motorola Mobility RAZR V3 Logo
64 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
