Question about Acer Computers & Internet
I am trying to conntect my acer aspire5732z notebook hdtv, however i am having problems doing so... i have both a vga and 1.82 audio y-cable (1/8--3.5mm stereo righ--angel male to dual rca male)... i tired connecting the cables to all the red and white outputs behind the tv but no sound... however, i am able to see my notebook screen on my hdtv... am just having problems getting sound... can you help?
  • 112 Answers
Try connecting the RCA cables to your TV's input jacks, make sure it says Audio input. Also, some TV's do not support audio in for VGA cables, if they do it's usually a 3.5mm jack labeled PC Audio or PC Speakers.
Posted on Mar 24, 2011
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
Why my acer aspire5732Z-443G25Mn webcam doesnt work?help me to fix the problem.
Seems like you need to install the driver for the webcam, you can download the driver from the following acer site, http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1246
Sep 08, 2011 | Acer Aspire 5630 Notebook
How to connect my acer D255E to the TV
According to the limited resources that I could find your only video output is a VGA port. Most newer televisions, predominantly LCD televisions will allow a direct connection via VGA. If your TV does not support VGA, can try using:
VGA to HMDI for HDTV's - Amazon search http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=vga+to+hdmi&x=0&y=0
With these I typically recommend a full force converter over a cable, but often times cables will work. Remember that with a VGA to HDMI cable only, this will only pass video and not audio. You will need separate cables for audio.
If you have a non-HDTV try this: http://www.amazon.com/VGA-Adapter-S-Video-Cable-Video/dp/B000Y7T5UU/ref=sr_1_1?ie=UTF8&qid=1315249911&sr=8-1
Use either S-video or RCA connectors to your TV.
Sep 05, 2011 | Acer Aspire One D255E13438 Netbook
I have an Acer aspire m3200. I tried to connect it to my hdtv, i got picture but no sound using the VGA cord, and got nothing using the HDMI cord. Please help
Using a vga cable to connect your laptop to a hdtv is very easy but the cable does not transfer the audio signal, you need another cable aswell. You need a 3.5mm jack to jack cable, one end plugs into your headphone socket on your laptop and the other end plugs into the pc audio socket at the back of your tv (usually next to where you plug in the vga plug).
May 28, 2011 | Acer Computers & Internet
How do i connect my laptop to an hdtv with pc input to view movies
If the PC Input is VGA, then get a VGA cable from Walmart or BestBuy or Ebay.com. Make sure the male/female ends are the right type for the computer and the hdtv.
Sep 24, 2010 | Acer Aspire 4520-5582 Notebook
Connection vga to tv
on the left side i think !! u have a yellow connector named Svideo !! if u have the cable corresponding this connector, connect it to ur TV via the Video input and press ( fn + F5 ) on ur laptop.
if u need audio !! connect the audio output of ur laptop to the audio input of ur tv with an audio double layer cable.
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Hooking up to the tv, aspire one acer notebook???
hi there, try a 15 pin male vga to vga cable ...select vga mode on monitor
May 17, 2009 | Acer Aspire One PC Notebook
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
May 09, 2008 | Televison & Video
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
