Question about HP Color LaserJet 2600n Printer
Magenta Cartridge The quality of whatever I print if anything red/magenta needs to be printed comes out horrible, pictures look greenish/yellowish. I can not get it to print nice red colors at all.......I have done most of the truoble shooting....bran new cartrdiges, etc. please help.
  • 3 more comments
  • sreenishcv Aug 05, 2008
    i have the same problem, please help me
  • Anonymous Aug 12, 2008
    red colour is showing as yellow colour while printing
  • mallory236 Aug 16, 2008
    You are the best, and my husband!.......for you, finding the solution, and my husband taking it apart. As soon as I read your solutionI knew that that was probably the issue. I remember once the magenta cartridge making quite a husband said the lenses were all covered, my print jobs are beautiful again, nice true colors!!
    This website below was very helpful in showing how to take it apart, it is instructions on how to recycle parts, so you will not need all the information. He said it took about an hour......
    Thanks again!
  • gtemples Aug 22, 2008
    When ever I print anything with red, it comes out with yellow mixed in.
  • phillipm May 11, 2010
    I have the exact same problem...
    I have also just replaced with a new toner and still have this problem.
I have just found a solution on the hp support forum that says:-
Common problem of scanner optics dusted over requiring removing the laser/scanner, uncovering and cleaning mirrors and lenses. See the attached procedure. Takes about an hour, no parts.
On the second message on the following link you will see an attachment that has instructions for the above.
Posted on Aug 04, 2008
  • phillipm Aug 05, 2008
    I've just tried the solution and now the problem has gone and now the red is back and all other colours are looking better!
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
We have replaced the magenta imaging unit and no magenta is coming through can you help
Ensure you removed the cellotape from the cartridge. pull out and put back cartridge.
Jul 29, 2008 | Minolta Office Equipment & Supplies
When I print a picture it is greenish. All the
You need to make sure you are not using the photo magenta, your printer doesn't use photo magenta and it leaves the prints green. You need also to run the nozzle check print by holding the resume button until the green light flashes twice, and see if all colors are printed. If not you need a new printhead, the part number is on the side.
Nov 11, 2009 | Canon I960 InkJet Photo Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printer won't print magenta color; prints appear yellowish green
The 'belt' or 'ribbon' at the toner cartridge was loosened.
Nov 11, 2008 | IBM Office Equipment & Supplies
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
C500n color problem
Try using another magenta/yellow cartridge.
Draw 4 rectangles colouring them 100% C, M, Y, and K and print.
Check the print and see which colour print is not appropriate
Oct 14, 2007 | Lexmark C500n Laser Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Incorrect colour is printed
I would try to replace the printhead and the magenta cartridge at the same time. Lots of people with leaky cartridges have this same symptom only, it is with whatever color is malfunctioning.
Apr 25, 2007 | Canon i850 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
419 people viewed this question
Ben Johnson
