Question about Vizio P50HDTV10A 50 in. Plasma HDTV
Tv comes on no picture let it warm up turn it on and off and picture comes on eventually .it was only afew minutes now it takes an hour or more im mike 50 in vizio 2007or 8 my second one
    President:
  • 1,623 Answers
Either a mosfet or capacitors are ready to fail check the power board for bulging on the tops of the capacitors and replace with the same
Posted on Mar 24, 2011
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
Sound takes up to an hour to come on, Mitsubishi 35'' tv
A $700 dollar estimate for a sound problem seems out of line - get asecond opinion (did some one look at it or just a guess). If the sound eventually comes on you probably have a connection (internal) problem or a intermittent part in audio section -cap o/p IC.
If you use a satellite or cable box can you hook your sound from that to an audio system thereby bypassing the TV?
Sep 30, 2009 | Mitsubishi CK-35308 35" TV
DLP TV - After warm up - colors smear
Did you ever figure the problem out? My TV is doing the same thing.
May 11, 2009 | Mitsubishi WD-73927 73" HDTV
I am losing my picture within 1 minute after light comes on.
Hi There,
Well, I wish it was that easy. Usually there is a temperature circuit with a thermistor or "Heat Sensitive" Transistor which only a technician could troubleshoot and detect. But, all is not lost yet, here is a simple solution that just might work: Open this thing up and take a feather duster and try to remove as much dust as possible. Gently drag the feather duster across the surface of the circuit boards. Do not use any pressure, you don't want to disturb the componants. If you have a little mini vac that would be great!
Just remove as much dust as you can without harming anything.
Hopefully, this will allow your TV to breathe and illiminate the overheating problem.
Have a great day!
Mar 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
176 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
