mostly the high pitched noise is the rapid vibration of the tap washer
it indicates a faulty washer
a local plumber can replace the washers and diagnose any other problem
They should have an ability to store up a charge while playing, but it would be at a slower rate, so if they were playing several hours they would have a significant charge built up, but not in only one hour of playing while connected.
They would charge faster when not in use.
Typically there is a "Battery condition" icon in one corner of the screen. If for some reason, it goes blank, & the device still plays, consider 7 hours of charge time sufficient for wee pocket size devices & Dig, Cameras.
Your impeller may have a locking bolt that goes through the center of the impeller. If it does, this has a reverse thread on it. If that is not the issue you may insert a skinny screwdriver into the vents under the motor to jam the fan, thus securing the motor shaft. You may carefully insert a screw driver into the impeller vanes to twist off the shaft.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
About 6L in a day, about 180L in an average month and about 2,191.50L for most years (except leap years).
You multiply .25L x 24 for a day and that gives 6L, then 6 x 30 for average month = 180L and finally 6L x 365.25 = 2,191.50 in a year, as there are 365.25 days in most years.
Short answer would be "Too much water wasted -- fix the lerky faucet!" But what does this have to do with PC Desktops?
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
hi, the problem could be that the philips 4gb player is not charging properly. the jack could be loose, try connecting the jack with the charge chord and confirm that it goes all the way. also try resetting the philips 4gb player. this should solve the problem. cheers
