Question about Acer Aspire One PC Notebook
I have a laptop and the screen is blank. i tried to follow the 'checking files' routine but when this is finished, no matter what button is pressed, you get the blank screen. how can i fix it please??!!!
  • 135 Answers
Try this... Remove the battery. Then Press ESC key for about 2 minutes then put the power adaptor while continue pressing the ESC key + Power button.
Posted on Mar 24, 2011
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
http://ccm.net/forum/affich-108275-toshiba-laptop-cannot-reach-login-screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
http://forums.toshiba.com/t5/Windows-7/Windows-7-won-t-start-black-screen/td-p/157700
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Why is screen blank?
You never said if it worked with external monitor. You also didn't say if you tried the [fn]+[Fx] key combination on the keyboard to try and switch displays.
But, if you look at the screen closely, at an extreme angle and can faintly see the graphics then that means the backlight has blown out. For the displays with LED backlighting it's usually just a wire or circuit to repair. For the screens with CCFL (fluorescent) lighting it's a simple matter of replacing the inverter board.
Mar 14, 2016 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
Turned of my laptop yesterday. now it wont turn back on, all I get is a black screen and the white arrow can anyone tell me how to get it to work again
Your laptop HAS turned back on.
One thing that is a problem is that the operating system hasn't finished loading.
You may need to use the recovery routine, or the hard disk could be dying.
Jan 30, 2015 | Acer Aspire Computers & Internet
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
Blackscreen on start up
Welcome to fixya,
Acer Blank screen at startup My Acer Aspire One notebook goes to a blank screen at startup.
BIOS Recovery Systemkat107x130.jpg As awful as it sounds, this is a fairly common problem with Acer Aspire notebooks and it sounds like you have an issue with the BIOS - as long as you can see the power button and hear the fans running to indicate that it is not a power issue. Luckily, these notebooks come with a built-in BIOS recovery system that should get you up and running without damaging or losing any of your files. Know that doing this may void your warranty, so if you have a warranty, you should talk to Acer directly. Follow these steps EXACTLY, and it should work for you:
  1. Format a USB memory stick to FAT. Make sure it is bootable.
  2. Download the latest BIOS from the Acer website. Follow these links for BIOS for Aspire One 150 or this link for BIOS for Aspire One 110
  3. Put the FLASHIT.EXE and the BIOS file in the root directory of the memory stick.
  4. Rename the BIOS file: ZG5IA32.FD. It is important that you get the file name exactly right.
  5. Remove the drive.
  6. Turn the Acer off, but make sure you have a working battery and AC power connected.
  7. Insert the USB memory stick into a USB port.
  8. Press Fn+Esc and press the Power button at the same time. After a few seconds, release Fn+Esc.
  9. The power button should be blinking. Press it once.
  10. At this point, the BIOS will flash - don't press anything or interrupt this process. If you've done it right, the power button will stop flashing and the notebook will reboot. When it is all done, everything should be set to reboot.
Because you have an Acer Aspire One and you are getting the blank boot screen, I'm betting that this will solve your problem. If you are still having problems after following these directions exactly, then let us know and we can try to troubleshoot hardware or screen issues that may be the culprit.
Hope this helps.
Dec 18, 2010 | Acer Computers & Internet
Error 5100
First try to reset the printer.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
If your product is new, perhaps some packing materials are still taped to the inside of the machine.
Look for a bit of paper jammed in the printer, perhaps where you cannot see. You may need to lift the scanner cover.
You may need to reseat the print cartridges. Follow the instructions in your manual to remove/reseat the cartridges. Wait for the unit to finish its preparatory routine - about 1 or 2 minutes.
If you still have a problem, your printer may need service by a qualified tech.
Dec 12, 2009 | Canon MX300 Office All-In-One Printer
F-6 showed up on my microwave window
self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
Jan 26, 2009 | Whirlpool MH7140XF Microwave Oven
MY COMPUTER WONT START UP!
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Jan 13, 2009 | Acer Aspire One PC Notebook
Screen goes blank
Your Computer enters Stand-By mode when untouched for more than one hour. This appears to be NOT A PROBLEM but the SETTINGS need be adjusted. Follow these SIMPLE steps to resolve it: -
(1) Goto Control Panel>Power Options>Power Schemes,
(2) Set the System standby to Never.
(3) Click Apply.
(4) Click OK.
Your Problem finished.
SAHAJA YOGA IS THE ONLY GATEWAY TO THE KINGDOM OF GOD AND IS THE CULMIINATION OF ALL THE RELIGIONS AND SPIRITUAL TRADITIONS OF WORLD.
May 24, 2008 | Computers & Internet
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
