I have a peavey pro-fex 2 preamp/FX ver 1.3 controller and when powereing up, get DSP interface error. Do you know what this means or how to fix it?
    Problem Solver:
  • 11 Answers
Your Profex likely has a dead NiCD battery. You are getting this error because this battery maintains your personal effect settings on an SRAM chip that requires constant power to "live". You can try reinitializing the SRAM on your unit by doing the following:
1. Power off your Profex.
2. Press and Hold the "PLAY" and "GLOBAL" buttons while powering the unit on.
3. You should see a message on the display that reads "MEMORY INITIALIZED". Afterwards the Profex should act normal.
4. If your internal battery is getting low or is already dead, it is going to start leaking (if it hasn't already). YOU NEED TO GET THAT BATTERY CHANGED NOW!!!!! If enough battery acid leaks onto the circuit board, it will ruin your Profex forever.
Posted on Jan 09, 2010
  • scordare Aug 20, 2011
    Thanks! I had exact same problem with a ProfexII. After replacing corroding internal battery and cleaning up the circuitboard, I also recieved this message. After the re-initialize it works great!
My peavey transtube fx is blinking DSP Interface error (resetting system) what should i do? it wont get past that message..
Posted on Dec 26, 2013
First try to reset the factory settings.Second, check the backup battery... Solomon
Posted on Jan 26, 2011
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
How can i reset my password in my new dsp 7500 ipr 2 peavey amp
I think you should search for a reset button, beware you loose probably all settings
May 27, 2014 | Peavey IPR 7500 DSP 7500 Watts D-Class...
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
Yamaha DSP-A3090: All video settings trip unit and it turns off
Hi...
Is the first set "stereo" settings and the 2nd set "surround" settings?
If so that may mean that the surround speakers arent all connected right.
Jan 14, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Jan 07, 2009 | Shure SM58 Professional Microphone
1,068 people viewed this question
 Grubhead
Grubhead
