Question about New Bright Bright 114 Scale Mud Slinger - Hummer
I need to find a 19.2 V battery and remote for my Hummer H2 Mud Slinger. Where do I look?
  • 3,018 Answers
A 1:14 Mudslinger requires a 6 Volt battery. Not a 19.2 Volt. Now when you go purchase this battery make sure it says 6 Volt not a 6 Cell. Here is the style battery you need. http://www.all-battery.com/6vrccarreceiverbattery.aspx
Starting from the top left you can choose the first 5 depending on the shape of the one you have for the RC and the mAh you want. The term mAh indicaters milliamp hours. Basically how long the battery will last. More bang for your buck basically. But they cost more too. They will all function the same. But the ones with less mAh will run out of juice sooner and have to be charged. All these connect the same way from the same style connector. So don't worry about that. Hope this helps.
Regards, Tony
Posted on Mar 24, 2011
    New Friend:
What kind of battery 9,6 volt i need to buy for a New Bright Hummer H2 (the chemistry of the battery) ?
Posted on May 28, 2014
Hey, you can try ebay, Amazon or Google shopping.
Posted on Jul 11, 2011
Why is the service 4WD message on all the time and diff lock light flashes and dos not lock?
Hummer 4wd service light reset Questions & Answers - Fixya
www.fixya.com > Forum > Tags > 4wd service light reset
Hummer h2 2003 55000 mill ... service 4wd the liht is on all time Remote the battery wire from the car for 20 ... My 2006 H3 will not come out of 4 wheel drive?
Sep 22, 2015 | 2006 Hummer H2
When I connected diagnostic/testers to the OBD-II connector on my 2007 Hummer H2 SUV, they did not work at all, does anyone know why ? What are the exact pinout of this connector on Hummer H2 ?
Data Link Connector (DLC) Pin
Wire Color
Circuit No.
Function
Not Used
PU
1132
Class 2 Serial Data
Not Used
BK
1050
Ground
5
BK/WH
1851
Ground
6-15
Not Used
16
OG
640
Battery Positive Voltage
Dec 26, 2014 | 2007 Hummer H2 SUV
I have a 2003 hummer h2 and the back doors and trunk will not lock with the remote what can i do.
in the key there are 2 batterys one section for the imobiliser and the other for the locks replace batterys and recheck you may also want to check the fuse under the drivers side dash. But if its just the rear of the car sounds like a wire relay problem. But check fuses first.
Apr 22, 2012 | Locks & Locksmithing
2004 Hummer H2
If this happen only after you replace the battery, then you need to go look around where the battery is at, maybe a vacum line came off, vents work off of vacum.
Jul 02, 2010 | 2004 Hummer H2
Just got H 2 2005 4 buttons 4 the 4 wheel drive
Use 2 wheels, the other 4wd low ,for climbing at slow speeds: 4wd high, for driving on low traction roads,like mud or snow,at medium speeds: 4wd auto full time all wheel drive, for highway speeds on slippery surfaces, like rain or light snow.
Jan 12, 2010 | 2005 Hummer H2
Hello, my '06 H2 is having problems w/ its Door locks!? My 2 remotes both stopped workin in 1 day and when i turn truck off, it automatically starts trying to lock & inside cabin lights stay on!?
ok sounds like you need to reset you alarm system.disconnect the batterie anf reconnect 2 times should cause your comp alarm to reset.
Sep 28, 2009 | 2005 Hummer H2
Why doesn't my remote or key open the rear lid of my Hummer?
A denter or specialist can service that portion because there is a problem in the key cylinder and lock mechanism and if you try somebody to repair without knowledge and he may scratch the paint for using the lever and damaging the plastic decor .
May 30, 2009 | 2004 Hummer H2
Remote the battery wire from the car for 20 minutes make and plug it back this will reset the computer of the car if the light is on you need to service center and get it checked....................
Jun 08, 2008 | 2003 Hummer H2
New Bright Bright 114 Scale Mud Slinger - Hummer Logo
378 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
