Question about PfaFF Creative 7570
Model 6091. I can't get the presser foot to go completely down and rest on the fabric. Can you help?
    Scholar:
  • 89 Answers
This is a comon problem with the pfaff 7570. The spring that applys the presser to the foot is all gumed up and needs to be removed cleaned and lubricated. I dont know if you want to try this yourself. You will need to remove the top and side covers and upper tension unit. Can be tricky. A pfaff repair shop should charge around $30. I will go over the steps if you want, let me know. But like i said i can be tricky.
Posted on Mar 24, 2011
  • 3 more comments
  • Jojo4a Apr 10, 2011
    Hi Nate_1 I have the same problem I would like to know the steps to fix.
  • nathan lewis Apr 12, 2011
    Sorry it took so long for me to respond.
    I would be happy to help you out. First can you get the panels off without my help, if so do that.
    Also what is the exact model number of your pfaff. This will help me discribe it better, it is different on every pfaff.
    thanks
  • Jojo4a Apr 13, 2011
    Not sure how to get panels off. My husband is an electrician and is generally pretty handy if you can give us the steps. I have Pfaff 7570. Is there another number I need to tell you?
  • nathan lewis Apr 14, 2011
    7570 great machine. Ill start with the panels
    1remove stitch guide, just bend it and the pin on each side should pop out
    2 remove side cover/light bulb cover- Looking down on the top of machine on the far left side you will see a small screw down inside about 2 inc. losen this screw about 2 turns and the side panel should come off.
    3 remove top panel- remove the 2 small philips screw on the top. Then pull up on the left side and wigle the bobbin winder. It should slide to the left and out.
    4remove light bulb
    5just infront if the light bulb there are 2 small philips screws that hold the front panel on, remove them.
    This is were things get tricky to explain.
    The goal is to remove the tension unit and a full componet.
    It is held on buy 2 -15torks screws and a small spring
    6 remove the small spring on the right side of the tension unit, this spring is what puts upward presser on the needle threader. After you remove the spring becarfull when turning the handwheel not to brake the needle threader.
    7find the 2 screws that hold on the tension unit, one is on the top and one is on the right side. The one on the right side just needle to be lossens not remove.
    The tension unit should be loose and ready to remove
    8 put the takeup lever in a position that it will not get in the way of the tension unit.
    9 lighty pull on the front panel(do not brake) and lift tension unit out of position.
    10 on the top of the presser foot bar there is a small pin and a spring in it. remove then and clean them up. They may be stuck in there very tight.
    11lubricate the spring and the presser foot bar and put it all back together again.
    I hope this is at all helpfull. Hard to explain without pointing at the parts in the machine.
    Let me know how it goes.
    Have fun
  • Jojo4a Apr 16, 2011
    Hey Nate, thanks sooooo much. We followed your steps and presser foot works great now. Again thanks so much!!!!
Posted on Apr 13, 2011
  • Debra Greene
    Debra Greene Sep 06, 2014
    I have a model 1475 cd Pfaff and having the same problem with the pressure foot , what can i do to fix it ?
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
Model 60-7000M. All works except foot rest. It will not close. Help!
Not sure what you mean by foot "rest." If it is presser foot, then you may not have the correct presser foot for your machine (basically, there are 3 types--low shank, high shank, & slant shank). Usually, there is also a pressure adjustment for the presser foot that increases the amount of pressure applied to the fabric and feed dogs. Consult your owner manual. Pressure adjustment is usually either a dial, a plunger type on the top left of the machine (pushing down increases the pressure--push down on the outer ring to release it), or a screw at the very top of the presser foot bar (sometimes under the top lid).
Dec 29, 2016 | Sewing Machines
When I sew silk or fine fabric the thread breaks and the fabric bunches up, what am I doing wrong, I first had the A foot and changed to B, changed the needle and still the problem persists
Check to be sure you are using needles and thread that are compatible with the fabric. Generally, finer threads will work better on fine fabrics along with a smaller needle. Be sure to change needles frequently as dull, bent, or nicked needles will cause very frustrating issues.
All About Needles
Remove the thread completely from the machine. RAISE the presser foot and rethread from the beginning, making sure the thread path is correct.
Some machines have a presser foot pressure adjustment (consult the owner's manual). Adjusting the pressure that the presser foot applies to the fabric & feed dogs is helpful when sewing especially fine or heavy fabric. Also, when sewing fine fabrics, loosening the tension could be beneficial.
Changing presser feet may also help, ie try using a straight stitch foot vs a presser foot for zig-zag stitching.
Something else you can try is finding a presser foot with a teflon finish or a roller foot that will glide or roll with the fabric through the machine. Even if you can't find a brand name presser foot for your particular machine, an adapter shank can probably be found that would allow you to use snap-on feet of all different designs and uses. Provides a lot of choices for presser feet for less than purchasing a brand-name presser foot. There are snap-on kits available on eBay and other auction sites.
Some machines also can take a straight-stitch needle plate--usually an additional accessory that can be purchased. The hole where the needle penetrates the needle plate to access the bobbin thread is actually a small round hole. With a zig-zag needle plate, the hole the needle penetrates is a wide rectangular hole that can allow fine fabrics to be pulled down through the hole. Zig-zag capable machines usually have a zig-zag needle plate as standard.
Feb 22, 2016 | Sewing Machines
No knob to adjust presser foot pressure. Space between feed dogs & presser foot is too tight to pull a piece of fabric out with foot down. Diagonal seams get pushed out.
You should not be able to pull fabric from the machine when the presser foot is down. The presser foot should always be raised before removing the fabric.
Are you trying to darn or quilt something without the feed dogs activated? If so, there are special presser feet for that purpose that are shorter in height (ie darning foot) which allow more space between the presser foot and the stitch plate so the fabric can be moved freely.
Apr 17, 2015 | Janome Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Pfaff 6091 how do i set presser foot height ?
If you got inside and cleaned and oiled the presser spring... then you have probably loosened the clamping mechanism that holds the presser bar. Get back inside. Look for a mark on the bar and adjust it so that the mark is UP near the clamp.
Feb 26, 2013 | Sewing Machines
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
Have a model 6091 Pfaff. The sewing foot will not lower complete
I had this same problem. On the bottom of the head there is a slide switch. Lay your machine on its back and you can easily see it. Slide it back and your problem should be solved.
Mar 29, 2010 | PfaFF Sewing Machines
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
641 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
