Question about Maytag Atlantis MAV6000 Top Load Washer
Washer only runs on delicate cycle
My washer will only operate on the delicate cycle
    Sniper:
  • 68 Answers
This sounds to me with the amount of information you have provided like you have a bad timer.
Posted on Aug 03, 2008
Clothes in bosche washer gets tied up in knots in spin cycle
Are you running a load according to the care labels?? If you run delicate or easy care items on a cotton wash this can happen. Just because an item is 100% Cotton doesn't necessarily mean it will tolerate a cotton cycle check the care label. Also, if for example a cotton cycle is 6Kg, the easy care will be 3-4Kg, Delicate and woollens will be approx 2Kg. Overloading can cause items to knot during cycle. Finally, check that your inlet water is not too hot. Repost if you need any further assistance
Feb 19, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
I have whirlpool washer model LSQ9549LQ2. It has burnt timer which I replaced. But now when I run washer it run only from one position from timer. Need help
Thanks for your question If your timer works in one cycle only say on the regular cycle You could have a defective one . If your washer has 2 speeds the delicate speed on your motor could be the problem
Jul 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
