Question about General Electric Profile PGS908 Range
We were using the stove and oven,,,suddenly the entire range shut off..now power to unit..circut breaker did not pop...fully plugged in..is there a reset switch
No problem with hotpoint electric range til I went to start oven, breaker kept tripping & making a popping noise
From having a Hotpoint myself, I can think of 2 possibilities.
Obvious answer would be electrical problem. If it trips the breaker you probably have a loose wire or a bad plugin socket. Did you buy a new "pigtail" plugin socket or did you use an old one when you got the stove? They say to buy a new one each time. If this is your first problem with this then your circuit can probably handle the load but see if the circuit that tripped says 30 or 40 amps. Also check to see if anything else is on that circuit besides your stove. There shouldn't be anything else on circuit. You may even have a bad circuit breaker but that seems less likely.
Second possibility is a bad baking element at the bottom of stove or bad heating element on top. When mine went bad, it made loud popping noises and sparks were flying. After that, the rest of the stove worked but not the baking element. I had to replace it for about $50.
My bet is on a loose wire. Be careful and unplug everything before you check! See if it's not fully plugged into the socket and see if the 3 or 4 wires coming from the thick plug wire are all tightly connected to your stove.
Jan 12, 2014 | Hotpoint RB757 Electric Kitchen Range
When I connected my oven to the electrical connection, the circut breaker keeps tripping. What can be wrong??
do you have a 50 amp double pole breaker for the stove ! it should be. if yes and it still blows, there may be a cord problem and it needs replaced.
Feb 09, 2012 | Thermador PRDS366US Dual Fuel (Electric...
I have an LG stove/oven and for some reason every time I press the oven functions the panel says 'lock'. So I can not use the oven at all. How do I unlock this feature?
Shut the power off at the breaker, wait 10 minutes, then reset the breaker. Sometimes the units need to be reset, as power failures will make the computers in them react 'funny'.
Aug 28, 2011 | LG LRE30451 Electric Kitchen Range
The oven was on and I was baking. Heard a 'pop' then the oven went off. I flipped the stove breaker on my electrical board back on and it took the whole power to my house out. Flipped the stove breaker...
element has blown, pop is it breaking, that heating element will need replacing, failing this and elements all working water may have gotten to the electrics this would cause the pop and shut down all electric as well.
Jan 02, 2018 | Heartland 3525SS Dual Fuel (Electric and...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Circuit breaker popping when stove top/ oven is on
thats how fires start when fuses keep blowing. Just use one at a time. Its probably over loading the fuse you may need a bigger fuse block. Call a local handy man if you havent already
Jan 03, 2009 | Kitchen Ranges
Fridgedaire Electric Kitchen Range
shut your oven off at the breaker and then pull it out and check the power cord where it connects to the ranges terminal block let me know what you find
Sep 11, 2008 | Frigidaire FEF352 Electric Kitchen Range
General Electric Profile PGS908  Range Logo
44 people viewed this question
Top General Electric Kitchen Ranges Experts
Craig Butler
Craig Butler
reliableservice
DROPNDEAL
DROPNDEAL
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
