Question about Dryers
My Whirlpool dryer has heat, but it has begun to shut off long before the clothes are dry. The lint filter is clear, and I vacuumed the behind back panel. Could this be the thermostat? And where do I find it, if that is the problem?
  • 96 Answers
Bad moisture senser
Posted on Mar 24, 2011
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
I recently had the heating element replaced on my whirlpool electric dryer model #LE5800XSW3. Prior to replacement, clothes dried completely in one cycle. After replacement the clothes take at least two...
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 22, 2011 | Whirlpool Dryers
I have a whirlpool dryer (LER7646EQ2) that is heating but clothes take forever to dry and the lint trap appears to be trapping less lint
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 20, 2011 | Whirlpool Dryers
Dryer shuts off before dry. not dry.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Jan 06, 2011 | Kenmore Elite HE4 Electric Dryer
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My dryer dries for a short period time and senses that the cloths are dry before the cloths actually are dry. Can I reset the electronics some how?
no. what you are getting is an over heat sense and is shutting the unit down this is a safety type of thermostat and will shut down the heating cycle prematurely as it will with a clogged vent or lint filter
Aug 23, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer no heat&wont shut off
if youre dryer is a sensor dry thats tells you when youre clothes are dry it the moisture sensor which is located below the door in the vent where the lint filter goes
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Dryers Logo
27 people viewed this question
Top Dryers Experts
