Question about Refrigerators
Lights are on no one home {compresser not kicking in wondering if there is a fuse that blows} cheers
    Sergeant:
    Champion:
  • 202 Answers
You have a starting problem.... you need a start relay and capacitor Cheers bro
Posted on Mar 24, 2011
No compression, decompression jammed
Valves could be sticking closed or open causing (good or bad compression) that or de-com-lever if faulty somehow.. And you need to do a compression test
Oct 04, 2014 | 2004 Yamaha WR 450 F
Citroen c15 van i have fitted a radio only when you turn the side lights on it blows the fuse
Does the radio work if the dash lights are off?
I'm wondering if the power and lamp wires are reversed in the 3 wire connector that plugs into the side of the radio.
satellite radio receiver
Aug 24, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Electrical problem. 2000 holden rodeo
battery capacity is irrevelent and fuses blow because of excessive current flow not from battery size
have an auto electrician check ot out as it may be a bad ECM
you just say fuses but each fuse has a capacity and belongs to a particular circuit so if it is a high amp fuse check thew units on that fuse for shorting out
ie 60 amp fuse for ignition, ECM , power steering pump
5 amp fuse for clearance lights etc
May 20, 2017 | Cars & Trucks
I have a 1994 Isuzu 3.2v6 Trooper or Bighorn which is called in Japan. The 7.5 amp fuse started to blow recently. Sometimes it'll work for a few days and sometimes it keeps blowing the fuse. The three...
whatever this fuse controls is drawing too much power, you need to know exactly what this fuse is for before you can find the problem,it may be the fuse for more than one thing.......hope this helps........cheers.
Sep 06, 2011 | Isuzu Trooper Cars & Trucks
My a/c is blowing out hot air and the compresser wont kick on
CHECK THE COMPRESSOR FUSE AND RELAY.IF BOTH GOOD.PROBLEM COULD BE LOW REFRIGERANT LEVEL OR FAULTY AC COMPRESSOR CLUTCH COIL OR DAMAGE LOOSE WIRE TO CLUTCH COIL.FAULTY LOW PRESSURE SENSOR.
Jul 19, 2010 | 2004 Hyundai Santa Fe
Very hard to kick start
i dont know what your timing is relevant to flicking the compression switch and kicking, but get the engine to the compression stroke and then as you go to kick it hard, flick the switch at that moment. timing is everything. i had an old yamaha tt 500 that kicked back so hard my foot slipped off the kick start and kick lever came up and took the skin off my shin.. it took quit a bit of time to get the timing but once i did, it was easy.. hope this helps.
May 19, 2009 | 2005 KTM 640 LC4 SM
Blows low volt fuse comp and cond fan wont run only supply fan runs
you check the fan motor and the compressor winding and terminal you have a short
Apr 27, 2009 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
