Question about Nintendo Wii Console
Unable to connect to internet, error code 51330
  • 112 Answers
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings.
Nintendo Customer Service
Posted on Mar 24, 2011
5 Suggested Answers
larkin71
  • 38 Answers
SOURCE: connection to internet on wii system
try to set your channel to either 1 or 11.set also your router's broadcast setting to 'mixed'.place your wii near router with no interference from microwaves or such.if router setting is set up to allow only selected pc's (or mac addresses),don't forget to include wii's mac address to enable it to have access to the router.if your router password type is wpa,make sure also you know whether it's wpa-psk AES,wpa2-psk AES or wpa-psk TKIP,you need to consciously choose the right one on your wii internet setting.also,you could switch the dns ip addresses around like put 2nd ip address in primary and 1st ip address in secondary.no guarantees,hope this helps.
Posted on May 07, 2008
saif123
  • 104 Answers
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
Posted on Jul 22, 2009
  • 12 Answers
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
Posted on Nov 16, 2009
  • 1234 Answers
SOURCE: can not connect to the internet error code 51330
Error Code: 51330This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 26, 2010
What is error code 51330? This code keeps popping up when I try to connecting to my Internet and I have no idea what to do so can you help me please?
Its either an incorrect wifi password or something with your router. That error indicates it is unable to connect to the wifi that is trying to connect to.
Apr 02, 2018 | You Video Game Consoles & Games
Error code 51330 on wii
They have stop the Internet connection for what reason ikke dont knowhow maybe use IT og wii u
Oct 12, 2014 | Nintendo Wii Console
Trying to connect to the internet through Wii but getting error messgae # 51330
Error Code: 51330
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings.
WEP AND WPA Security keys are case sensitive.
Aug 28, 2011 | Computers & Internet
I keep getting error code: 51330 when trying to connect wirelessly to the internet.
This was the information on error code 51330 on Nintendo.com
Error Code: 51330
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Jul 20, 2011 | Nintendo Wii Console
I am trying to watch a movie on net flix, however everytime I tried to look for the internet service the following error comes up: Error code 51330 is unable to connect to the internet.
Hi there!
Error code 51330 on the Wii means that the password you entered into the Wii to set up your internet was entered incorrectly. You will need to go back into your internet connections settings menu on your Wii and enter the correct password/security key for your router. Please remember the security key is case sensitive.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
I can't get my wii to connect to my wireless connection. I went to Internet settings and did Put the wireless connection name, did the connection test and it said unable to connect to Internet. The error...
go to settings wii settings then click internet and click any connection search for access point then type in pass(optional) and then click ok go back to wii menu and connect
May 02, 2011 | Nintendo Wii Console
Unable to connect to internet error code 51330
Here is a link to your error code.If you need more help than what they suggest,their number is there too.
http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=51330&system=Wii&locale=en_US&action2.x=7&action2.y=17
Good luck and game on!
Jul 15, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
299 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
