Question about Dell Dimension 3000 PC Desktop
Can't start the computer, only have the dell screen won't boot
  • 79 Answers
For this problem you can usualy solve it by booting into safe mode.
While booting up hold down f8, there should be a menu that pops up and allows you to select safe mode, or startup repair(on some machines). You want to select safe mode, safe all of your files, and then reinstall the OS.
Posted on Mar 24, 2011
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Inspiron zino HD won't boot up it just stays at the dell screen
Try booting into safe mode restart comp and its 1 of the f buttons f5 or something ea model number is different when in safe mode make sure you go to safe with networking and download new drivers of that doesn't work let me know ill walk u thru how to Chang the way you boot up your pc
Apr 03, 2013 | Computers & Internet
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
My dell computer says PXE-E53, on RealTek PCIe FE Family Controller Seriies V1.19: No boot filename received and then says no operating system found
First go to bios by press f10 (or kay for your model of laptop )and
select main menu and check display cd dvd drive and hard drive in information.
select cd dvd or hard drive to first boot .set network as lower than hard drive.dell-bios-uefi.jpg
in this pic netework is high piority for boot up. but there are no network server to boot up. there was showed as no network device, pls select hard drive and select key for change setting.
Oct 29, 2017 | Dell Inspiron 1200 Notebook
Dell vostro 200 F8 menu won't respond to repair
to access the recovery partition you need to press Ctrl and F11 when you boot up which should start the factory recovery process.
Nov 11, 2012 | Computers & Internet
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
My dell inspiron 1721 is stuck on start up. The screen with ctrl + F to enter build utility. Ive tried to reinstall vista but on the install. I get stuck on the load drivers screen. I have the drivers on...
Hi, first of all have you tried to run the diagnostics just to ensure the hardware functionality of your computer? if not, here's how: As the computer boots, press when the Dell Splash Screen appears. When the Boot menu appears, highlight the Boot to Utility Partitionoption, or the Diagnostics option and then press to start the 32-bit Dell Diagnostics. Press the key to highlight Test System Press to continue to 32-bit Diagnostics. Note: Express Test is the only test that will not require user involvement.
If there's no error found, that means, that your hardware most esp the hard drive (HDD) that came with your system is perfectly working fine and this isolated your issue that it's the operating system problem. It's good to know that you attempted to rebuild the OS just make sure it's the recovery cd that came with the computer. try to boot from the OS cd once again and reload / reinstall Vista. Here's the link for your reference (see step 4): http://support.dell.com/support/topics/global.aspx/support/kcs/document?&docid=DSN_339949&isLegacy=true#Issue4
Apr 23, 2011 | Dell Inspiron 1721 Notebook
Won' start up properly
Hello, you might be having an issue with a Peripheral Device in the computer, conflicting with it to boot up, please disconnect any USB devices, port replicators, or printers/scanner on the serial ports, if this solves the issue and you're able to access your computer, please reinstall the drivers for those devices, you can test each one of them to see wich one is the troublemaker.
Additionally if you don't have any peripherals connected, then please try to boot up in safe mode, to do so, please restart the computer, then when you see the Dell Logo, press the F8 key at start up, then please chose the safe mode option, and press enter. If you are able to enter safe mode, then please press the keys [Windows] + [R] and in the screen that pops up, type "msconfig", without quotes, go to the Startup tap and select, disable all. Afterwars restart the computer and let us know if it worked.
Apr 30, 2009 | Dell Inspiron 1501 Notebook
Start Up Problem
i believed its not the mother board, check the system setting (press F2 when dell logo came out on screen) maybe the boot sequence is not configured right, try to set
First Boot: internal hard drive
and also remove any USB drive or floppy disk or CD inside optical drive or memory card connected to notebook before trying to boot the machine.
Apr 02, 2009 | Dell Inspiron 6000 Notebook
Dell Dimension 3000 PC Desktop Logo
276 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
