Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hi- I was just wondering where exactly the antenna input is located??
  • Sharp Master
  • 8,457 Answers
The tv LCD screen is facing u.The antenna input is located at the near bottom on the right side bazel frame have a input hole that said ANT.
Posted on Mar 24, 2011
Finds no channels on autoscan, even though it found channels a few days ago in another location & another tv finds them in current location connected to the same antenna. Has a part gone bad?
Has the input source been set back to Antenna or TV tuner? Click on the Menu button on the remote and select input and check that it the correct source is selected
Jul 04, 2016 | Televison & Video
How do i set tv to external antenna
Not sure what you mean exactly. You can switch through the inputs on your TV by the remote or on the TV's control panel. If you are wanting to connect an antenna to receive over the air channels, there are many options available. These will connect to the coaxial input on your TV.
Nov 04, 2013 | Toshiba 32C120U
Aspect hitachi 65m200
You should have one or two antenna inputs. Select one and make sure the TV is set to that antenna input, usually, Ant A & B
Oct 29, 2013 | Televison & Video
RADIO ANTENNA LOCATION
Above the roof headliner.
Jul 26, 2017 | Audi A3 Cars & Trucks
Antenna analog input tunner broke off inside the box wondering if i could bypass it useing converter and the digetal input tunner
Yes, just make sure your converter box has composite and you're set to go. Your antenna will then plug directly into your converter box. If you end up needing more than one port (dvd player, gaming console, etc.), grab up an A/V switch which also works off of composite and you're all set to go.
May 12, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Which hole do I plug the cable into antenna digital input or ante
Hello ruthharris,
I think the antenna is built in :S dunno exactly may be .. btw there is [Antenna] button on the remote control
You can download the Manual of this TV by Clicking Here
Thank you for using FixYa.
Apr 12, 2009 | RCA D52W23 52" HDTV CRT TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
Hookup
Out to tv connects to your input or where the antenna for the tv is located. If you have an antenna hooked to you tv, remove it and hook in the vcr. Then put the antenna to input on the vcr.
Jan 21, 2009 | Zenith VRB410 VHS VCR
Have sound but no picture
you either smoked the video ic or apower supply feed to it ,
Oct 24, 2007 | Toshiba TN55V71 55" Rear Projection...
Tv problem
Mine (2005 vintage) is doing the same thing. Wiggling the connector at the rear of the set cures the issue. however, it must be a loose connection inside. How about soldering the connector?
Any other ideas on how best to handle the soldering of the connector inside the set?
May 12, 2007 | Sanyo DS24425 24" TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
