Question about GPS
I have a super star sharp shooter power mic would like to wire it to cobra29 lx le can you tell me what wire goes to what pin...
2 Suggested Answers
brittin
SOURCE: Cobra 29 LX LE antenna
I am having the same problem with mine....I bought it new and it worked fine for a week.. How did you fix yours?
Posted on Mar 28, 2012
Wiring code super star mic to rca copilot 14T 303
The colors shouldn't matter.... check the mic switch. and follow your wires to the mic plug. the common wire is normlly the ground to allow RX then when pressed for TX the other should then be your audio which will be connected to the mic element.. using this method you can wire any mic to any radio.. pending the mic element ohm value impedance is correct for the radio.
Dec 06, 2015 | Radio Communications
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Tell me how to wire a super star mic to a uniden pc76xl
look up the model superstar to a cobra 29 mic and you should have your answer.
Dec 29, 2012 | Radio Communications
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
When i turn on my connex 4800 dxl all that lights up is the power meter no chanel display or freq display no sound either
The voltage regulator on the right side of the radio (with the parts side up ) is located in between the 2 side screw holes is ether bad or the legs are broke loose . it is a A1869 transistor.can be replaced with a A473 Transistor . Basically it's the same as a Galaxy Radio ,Ranger makes the boards for (RCI ,Galaxy , Connex , North Star ,Super Star, General Lee .) Hope this Helps.
Oct 31, 2010 | Connex 4800-DXL 480-Channels Base CB Radio
I have alot of questions on how to use my dad's old camera stuff. the names of them are pentax LX that uses film, simul-shot 2, and super shooter polaroid land camera.can you go step by step how to use...
there are books written about photography but i will tell you a little,
shutter speed the faster the shutter speed the less light goes through this basically helps to take fast moving objects, now in darker situations you may decrease the shutter speed but you'll have to hold the camera steady and longer or tripod it,
the rest you can find on
http://www.dpchallenge.com/tutorial.php?TUTORIAL_ID=45
Jul 28, 2010 | Creative Labs Live! Cam Voice Webcam
Sv400 rev 1.0 motherboard the mic sockets are not working the rear socket has been linked out (speaker socket still workin) the front socket has 5 unconnected wires (mic power, mic in, ground, r-out,...
each motherboard has different pin connection, so its best to check the booklet that came with motherboared, in the book there is color colding for mic and headphone.
Feb 10, 2010 | Computers & Internet
Dm 452 microphone
this radio is made by PEIRCE SIMPSON and is wired like a cobra.
pin 1 shiels or ground
pin 2 is audio
pin 3 is transmit
pin 4 is recieve
shield is a bare wire wraped around the audio wire.i dont know the colors of the wires in the echo mic.the transmit wire will have contiuity with the shield wire when the mic is keyed that wiregoes to pin 3 . there should be 2 wires left. check these wires one at a time with the shield wire one will have contiunity . this wire will go to pin 4 recieve.the other wire will go with the shield wire on pin 1
this is the way you find how it wires. it will take an ohm meter to find whice wire goes where.
james morgan
morgans electronics
Mar 09, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
GPS Logo
64 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
