Question about LG 62SX4D 62" Television
The picture flashed green to black several times and the image went askew. Then everything went black and stayed that way. Sound remained on. After a few minutes, I tried to turn the unit back on and it did the white up and down lights ending with the two top lights on (now red). I have changed bulbs twice before when this happened and that fixed it. This time it didn't. One new thing that happens now (I know this is weird) is that when I turn it on the set chirps in the vicinity of the bulb and then it once again the TV turns off. I have tried unplugging the set for an hour as a read somewhere else. No help.
  • Lauren Carhartt Mar 24, 2011
    A "factory trained" tech replaced the ballast 6 months ago. Your answer makes perfect sense. Thank you
    Thank you again.
  • LG Master
  • 2,098 Answers
Hi lc99527,
This is an indication of faulty ballast board and or its power supply(gone to out-of-regulation) and once sense by the feedback circuitry it will automatically shuts off the power supply. First check for bad solder joints (crack/cold/dry joints) in that section. This is hard to spot, I would advice you use table/portable lamp or work in the brightest area to locate it. Once found, resolder it. Also check for leaky/dried electrolytic capacitor. Sometimes it has a bulged at the top but not all, you must have a capacitor checker to determine its condition. Shorted driver transistor in the ballast board will do the same symptom as well as faulty ballast transformer.
Isolating the symptom is technical and if you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for a qualified technician to troubleshoot the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 24, 2011
  • Jdvillanueva
    Jdvillanueva Mar 24, 2011
    Welcome, thanks for using Fixya and again have a nice day!
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
I have laptop by fujitsi it runs normally but the screen is completely black
When the display shows the following cases, that need to be replaced a LCD Inverter:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 16, 2013 | Fujitsu Siemens KBPC SX Keyboard
Laptop black out
When the following situations, you need to replace the LCD inverter:
More:http://www.lcdinverter.info/acer-travelmate-8001-lcd-inverter-p-2046.html
Aug 08, 2013 | Acer Computers & Internet
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Aug 04, 2013 | Sceptre Computers & Internet
The LCD light (green) flashes for like 6 times and then the pictu
even though the lamp light is not flashing I would think it is the lamp getting weak for some reason the Sony's do that.
Aug 19, 2009 | Televison & Video
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
SUPER DARK SCREEN, BLACK PICTURES
I have seen this several time the lens cable can cause this issue it could also be the back light or the LCD I repair these all the time If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Oct 02, 2008 | Casio Exilim EXZ75 Digital Camera
LG 62SX4D 62" Television Logo
144 people viewed this question
Computer Repairing
Computer Repairing
