Question about HP Officejet 5610 All-In-One InkJet Printer
How do I fix a carriage jam caused by a loose spring on the left side of the printer?
  • 93 Answers
Please follow the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00577763
this includes a detail instruction for the problem that you are facing.
-Please vote/rate/thumbs-up if you find this helpful.Thankz!
Posted on Mar 24, 2011
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
Paper Jam {Printer does not detect paper
Nov 18, 2010 | Office Equipment & Supplies
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
False paper jam message
Check the following Steps to Fix Hp printer carriage jam :
Sep 29, 2010 | Office Equipment & Supplies
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
HP 6110 Printer jams after 1 sheet
Thanks for contacting Fixya.com
Please try the bellow mentioned troubleshooting steps to help elliminate the paper jam and noise issue for your printer:
Things that cause a carriage jam error:
Dirty encoder strip.
Damaged encoder strip.
Encoder strip spring mount out of position so strip is slack.
Encoder strip not threaded through the emitter/detector that reads the lines on the strip. (just fixed a 5550 with this problem)
Emitter/detector that reads the lines on the strip is bad, this is part of the carriage PCA, (board).
Carriage stuck on side because service station is not releasing it.
Carriage stuck due to being tilted at wrong angle, if it's stuck a few inches from the right it needs to move farther to the right to be released, stuck a few inches from the left end move it farther to the left. (instructions probably on HP web site, they are there for the DeskJet 5550)
Carriage binding on rail due to ink build-up or lack of lubrication, (be careful what you use to lube).
Bad carriage motor.
Bad carriage drive belt.
Some machines have a timing disc on the service station motor and may indicate a carriage jam if the service station motor does not turn.
The cause could also be a loose cable connection on a small circuitboard inside the printer (The one that controlled the paper jam sensors) I fixed it by saudering the leads to the board until I had a good connection again.
Thank You and best of luck,.
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting a problem error 86:01
If you don't see a paper jam it's a carriage axis error. Try cleaning and then lubricating the bar well. Next look at the belt turn around on the non-motor end of the belt. You'll find a bearing in the spring loaded pully that wears out or ceases up. If the drag / friction is too high you will get the 86.01 error. I have included a link to a free copy of the HP Service Manual to help you get through it. The error is discussed on page 2-18 and 2-19.
Hope that helps you.
Feb 19, 2009 | HP DesignJet 500ps InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
