Question about Evga P55 Classified 200 (160LFE659KR) Motherboard
Pc freezes, says no operating system installed, keyboard freezes in bios,says no hard drives intalled...
  • Evga Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Posted on Mar 24, 2011
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Hp pavillion m7680n win xp freezes
The problem seems to be with RAM. Remove your RAM after switching the PC off and clean the contacts array carefully with a dry cloth, rub a little if required with a slightly coarse cloth. Put it back, hopefully will solve your problem.
Jan 14, 2012 | HP Pavilion m7680n PC Desktop
Whenever I turn on my laptop the screen is blank with a white dash mark flashing in the top left corner of the screen. What do I do?
That is the signal that the BIOS no longer finds an operating system installed on the hdd. All you are left to do is to reinstall it. Use the recovery disk that came with it.
Jul 05, 2011 | Acer Aspire 6920 Notebook PC
I have massive boot issues...Can't enter BIOS>laptop freezes. Can't load windows in any form safe mode or otherwise. Can't install new copy of windows either freezes or gives a file not...
If you can't even enter the bios, it means you have a hardware failure somewhere, as the bios is independent of the operating system (Windows) and only needs a functional power supply, motherboard, CPU, RAM and of course keyboard to navigate. A hard drive isn't even needed to enter the bios. In fact, it might be a good idea to remove the hard drive and try again to enter the bios, in case the hard drive interface is causing an issue. If you do manage to get into the bios, try to navigate to where you can set the bios back to factory default. If you still can't enter the bios after disconnecting the hard drive, then it's a matter of trial and error, swapping out RAM, the power supply, CPU and removing any other peripherals that may be removable (like a wifi card or DVD drive). If you can't reliably get into and then smoothly navigate the bios, I'm afraid it is unlikely that you'll be able to install and boot Windows.
Nov 13, 2017 | Fujitsu Siemens Amilo M1425
What does it mean when it just freezes up on the welcome screen? There is a blinking light
The hard drive is unable to boot the operating system - it may have gone bad. Remove it and reboot the computer and go into the BIOS to verify it's not the mother board. It should start up without the hard drive and allow you to go to the BIOS. If it does, then you have a corrupted or bad hard drive. If it's corrupted you can probably re-install the operating system to fix the problem.
Jan 19, 2011 | Dell Latitude D600 Notebook
All I get is a blank screen with a blinking curser
your system maybe having a hard time accessing on your boot up drive, going into bios and setting up the hard drive with an operating system intalled on first boot may fix your problem.
Oct 15, 2010 | Sony VAIO Notebook
Problem installation on Windows XP
Three things
1) Do you have enough memory at lest 1Gb
2) Is it a full genuine Windows disk. Some disks out there are a mixture of different things and some cannot find hard drive
3) Try another setup disc and see if it works
Sometimes the disk has a read fault
One last thing to try is Reset BIOS to default
Oct 12, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Western Digital My Book freezes computer on boot up.
Mine boots fine if I unplug (better yet, hold the flat button down on the back for about 5 seconds, and it will turn off).
Aug 31, 2008 | Western Digital My Book Essential Edition...
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Presario v2555us harddrive and bios
A damaged hard drive will NOT affect your bios, however a bad motherboard, ROM, chip, memory, etc. can cause your system to freeze when entering BIOS. You probably need to send it out for repair.
Sep 07, 2007 | HP Compaq Presario V2555US Notebook
Evga P55 Classified 200 (160LFE659KR) Motherboard Logo
57 people viewed this question
Top Evga Computers & Internet Experts
David
David
Larry Rider
Larry Rider
Josh Levin
Josh Levin
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
