Question about Toshiba 40XV645U 40 in. LCD HDTV
My Toshiba 40xv640u suddenly lost color in stripes running from top to bottom. However, it moves around and sometimes is normal.
  • Toshiba Master
  • 2,098 Answers
Hi Cindi_axtell,
Do the symptom also appear while you are watching movie through the dvd player? Let me know to assist you further.
Jdvillanueva
Posted on Mar 24, 2011
  • Jdvillanueva
    Jdvillanueva Mar 24, 2011
    Your unit need to take apart and check all cable connectors connected from the power supply to the main board and lcd controller board for loose connection. Also, leaky/dried electrolytic capacitor in the power supply section will do the same symptom. It needs a warm-up to make itself stable but it will get worst. Sometimes it has a bulged /dome at the top but not all, you must have a capacitor checker to determine its condition. If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for a qualified technician to troubleshoot the symptom.
    Also check first if the unit is under warranty/extended warranty, avail it because the manufacturer of your unit will fix it for free or a little charged only. Don't attempt to open the back panel, it will void the warranty.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
  • Jdvillanueva
    Welcome, thanks for using fixya and have a nice day!
Toshiba 40xv640u vertical ghosting
This will require a technician to resolve with some specially equipment.
May 14, 2012 | Computers & Internet
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Trying to get the color codes for the speakers wires someone cut my radio wires and im trying to install new one.
Usually speaker wires have a solid color, and a stripe of another color on them. Sometimes it's a solid color, and rings going around the wire of another color.
The striped wire is the Positive. Then there will be a wire, that is the same color as the stripe. (On the striped wire) This is the Ground wire.
Apr 29, 2009 | 1989 Mercury Sable
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Display Problem Black turns Red
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Nov 24, 2008 | Computers & Internet
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Problem with green color
One of your convergence IC's has burned out and needs to be replaced. If the green color is sagging from the top or bottom then the IC that handles the Green Vertical (GV) is bad, and if the green has moved inward on the left or right sides then the IC that handles the Green Horizontal (GH) is bad. Toshiba projection TV's typically use the STK392-110, and it is a good idea to go ahead and replace both IC's with the updated STK392-150's. If you do not have experience replacing convergence IC's then have a qualified tech handle it for you.
Jul 02, 2007 | Toshiba 40H80 40" Rear Projection...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 40XV645U 40 in. LCD HDTV Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
